> Cabinet identified the TTS sensor and the holes, ty, Know what it does now
oakdalecurtis
post Aug 27 2016, 08:34 PM
Oakdalecurtis
After I got the throttle body off on my '76 2.0, a couple of questions. There is a sensor under the throttle cable, white wire was broken off, I repaired the wire, what does the sensor do?
Also, under the throttle cable in the tin on the passenger side is a clean 1/2 inch hole, what is it there for, looks like it was taped over at some point?
Finally, there is a machined approximately 1 inch hole in the back of the engine bay wall about car centerline, in the circle in the picture with the blue glue residue around it, and the remains of a small black plastic cap were underneath it. What is the hole there for and should it be covered? Anyone on any of this stuff?
TheCabinetmaker
post Aug 28 2016, 10:36 AM
I drive my car everyday
First pic is the thermo time switch. The hole in the tin is for a push in plug wire holder. They are available new. Bug/bus part. The hole in the rear tin had a plug with a strap for the wiring harness. Iirc
- Lo-Fi Version Time is now: 26th December 2024 - 05:18 PM
