> rear susp. question
Aaron Cox
post May 10 2003, 04:49 PM
Professional Lawn Dart
hi guys, back from my week long lurking experience....
any way. i got my 140 lb welt. springs and my bilstein adjustable perch shocks now. next weekend is install day.
*what perch setting should i use?
*do i need a spring compressor?
*what's all this about tie-wrapping the spring into the perch?
*top or bottom perch?
can you guys help me out?
n e 1 been there done that? (IMG:style_emoticons/default/huh.gif)
Aaron Cox
post May 11 2003, 12:53 PM
QUOTE(driver66 @ May 11 2003, 02:01 AM)
ive got to change my original shocks and springs on my 72...the boges are wore out and my rear springs are so far gone everyone thinks its been lowered.{lots of negitive chamber} got to fix as fast as possible.looks and drives wierd.im setting it up for heavy spirited driveing ,but its a daily driver so got any good advice . im thinking 140 rears????? is these direct replacements for my originals??
i have the same problem, neg. camber and right rear bottoms out. looks lowered.
Aaron Cox   rear susp. question   May 10 2003, 04:49 PM
ChrisReale   I didnt need a spring compressor for my 180's,...   May 10 2003, 05:24 PM
Aaron Cox   my bilsteins have 6 notches with a clip that holds...   May 10 2003, 05:55 PM
ChrisReale   I guess give it a shot, and if you need a spring c...   May 10 2003, 06:01 PM
Aaron Cox   thanks a bunch. anyone else have the same springs...   May 10 2003, 06:04 PM
driver66   ive got to change my original shocks and springs o...   May 11 2003, 04:01 AM
Bleyseng   If your car has the stock springs use a spring com...   May 11 2003, 08:31 AM
Aaron Cox   ...   May 11 2003, 12:53 PM
Aaron Cox
  May 11 2003, 12:56 PM
Aaron Cox   also, should i replace bushingS?   May 11 2003, 01:01 PM
Brad Roberts   Zip tie to the top (you cant see if it went into t...   May 11 2003, 01:47 PM
Aaron Cox   thanks brad. anyone else have a tidbit to add? ;)   May 11 2003, 08:13 PM
driver66   how old is ''old'' for your spring...   May 11 2003, 09:02 PM
Jeffs9146   Dont forget about the camber shims! I had one ...   May 11 2003, 10:11 PM
Elliot Cannon   I bought what I was told was a 160lb "progressive"...   May 11 2003, 10:59 PM
Jeffs9146   Depends on the perch settings! Jeff   May 11 2003, 11:04 PM
Dave Cawdrey   I took stock springs off of Koni Reds w/out a comp...   May 12 2003, 12:37 AM
Brad Roberts   Correct. I knew he was going to "off" the old pare...   May 12 2003, 12:52 AM
KenH   Put a bubble level on the door sill and set the re...   May 12 2003, 09:06 AM
Dave_Darling   A private party can say things like, "As long as y...   May 12 2003, 04:01 PM
TMorr   Another way to avoid needing a spring compressor t...   May 12 2003, 05:16 PM
Aaron Cox   thanks.....they are original boge's w/ origina...   May 12 2003, 05:18 PM
Brad Roberts   Dave, if you where actually on Pelicans payroll/4...   May 12 2003, 05:22 PM
Jeroen   Since you have new shocks and new springs, it woul...   May 12 2003, 05:53 PM
Bleyseng   RENT ONE! Go to your Flaps or a rental shop to...   May 12 2003, 06:44 PM
Aaron Cox   thanks a bunch guys! hope i can get it all d...   May 12 2003, 08:41 PM
Aaron Cox   the deed has been done! only took about an hou...   May 18 2003, 01:20 PM
ChrisReale   <...   May 18 2003, 04:36 PM
Bleyseng   Got a 19mm front bar for you to buy. Cheap Geoff   May 18 2003, 07:41 PM
Aaron Cox   how cheap is cheap? i have acces to a parts car th...   May 18 2003, 09:51 PM
Bleyseng   $50, its a old school one without adjustable ...   May 18 2003, 09:59 PM
Aaron Cox   ...   May 18 2003, 10:01 PM
- Lo-Fi Version Time is now: 30th April 2025 - 02:57 AM
