> leak from oil cooler, case mounted cooler on a 3.2 six
worn
post Sep 12 2016, 10:29 AM
can't remember
Well, I got the newly converted car driven over larger and larger distances. Inevitably the oil temperature came up and the internal thermostat opened up. And out gushed oil. It looks very much like the 2 seals that go between the case and the oil cooler are leaking. I had to take the cooler off to weld the modification for the oil line bend, and I put it back with new seals. Again it is a six from a 1985 Carrera.
Any ideas about how to avoid this? I think I can pull this without dropping the motor, but not sure. Only obstacle is the tin over it. Suggestions most welcome.
Thanks.
post Sep 12 2016, 12:03 PM
914-6 GT in waiting
If you want I will ship you our Stompski pressure tester. It's super easy to use and will confirm if the cooler is good or not.
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 09:20 PM
