leak from oil cooler, case mounted cooler on a 3.2 six |
worn |
Sep 12 2016, 10:29 AM
can't remember Group: Members Posts: 3,378 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Well, I got the newly converted car driven over larger and larger distances. Inevitably the oil temperature came up and the internal thermostat opened up. And out gushed oil. It looks very much like the 2 seals that go between the case and the oil cooler are leaking. I had to take the cooler off to weld the modification for the oil line bend, and I put it back with new seals. Again it is a six from a 1985 Carrera.
Any ideas about how to avoid this? I think I can pull this without dropping the motor, but not sure. Only obstacle is the tin over it. Suggestions most welcome. Thanks. |
mb911 |
Sep 12 2016, 04:11 PM
914 Guru Group: Members Posts: 7,391 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Are you sure it wasn't just overfilled and leaked from the vent hose on top of the engine?
worn |
Sep 13 2016, 08:26 AM
Lo-Fi Version | Time is now: 6th January 2025 - 08:48 PM |
