leak from oil cooler, case mounted cooler on a 3.2 six |
worn |
Sep 12 2016, 10:29 AM
can't remember Group: Members Posts: 3,378 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Well, I got the newly converted car driven over larger and larger distances. Inevitably the oil temperature came up and the internal thermostat opened up. And out gushed oil. It looks very much like the 2 seals that go between the case and the oil cooler are leaking. I had to take the cooler off to weld the modification for the oil line bend, and I put it back with new seals. Again it is a six from a 1985 Carrera.
Any ideas about how to avoid this? I think I can pull this without dropping the motor, but not sure. Only obstacle is the tin over it. Suggestions most welcome. Thanks. |
mb911 |
Sep 13 2016, 10:42 AM
914 Guru Group: Members Posts: 7,391 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
That's another reason I am thinking about not using the engine cooler and just plumbing it all to the front of the car like Mark did.
mepstein |
Sep 13 2016, 11:06 AM
914-6 GT in waiting Group: Members Posts: 19,685 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
That's another reason I am thinking about not using the engine cooler and just plumbing it all to the front of the car like Mark did. I can see the attraction of just the engine cooler for a small engine. It's a clean, simple setup. But with the 3.2, it was going to need fresh air from the front anyway. But it adds at least $1k to plumb and cool it at the front. |
worn |
Sep 13 2016, 03:01 PM
That's another reason I am thinking about not using the engine cooler and just plumbing it all to the front of the car like Mark did. I can see the attraction of just the engine cooler for a small engine. It's a clean, simple setup. But with the 3.2, it was going to need fresh air from the front anyway. But it adds at least $1k to plumb and cool it at the front. Yeah, I thermostated in an extra mocal heater, but it is by the passenger axle in the back with double fans. Whether that is enough is open to question. I went that route after looking at the Wills build. Then he tells me it looks a bit hot sometimes. (IMG:style_emoticons/default/sad.gif) But I don't always drive in AZ. |
Lo-Fi Version | Time is now: 6th January 2025 - 08:48 PM |
