> Throttle Cable Replacement **Now In Progress** :)
JustinMeier
post Sep 12 2016, 12:11 PM
QUOTE(SLITS @ Jul 16 2009, 07:04 PM) *
There are no tricks ...
Remove carpets, pedal board, center console (if installed), center tunnel inspection plate and driver's seat
Pop connector at pedal loose and remove ball connector and nut.
Disconnect cable from throttle body in engine compartment and push it down thru the engine tin.
Crawl under car and pull the sheath loose from the firewall and pull cable out of tube.
push new one back thru and secure metal end on stub in firewall. You can push the sheathing back up through the engine tin.
Back in the car, fish the throttle cable end out of the center tunnel. Using a mirror, make sure it is not wrapped around the clutch cable. Put the lock nut on threaded end, screw the ball connector on and snap it on the bell crank.
Reassemble remainder of interior.
Go to engine compartment, secure sheathing to mount, pull cable and secure with barrrel connector to throttle body.
Wella .......................
Something like that anyway
Anybody want to add anything else or does this pretty much cover it?
ndfrigi
post Sep 13 2016, 03:21 PM
Looks like those cables are the clutch and speedo cable and not the accelerator cable. Like what mentioned above, accelerator cable is by the firewall and goes up and it should not be closer to the heat exchanger or headers.
JustinMeier   Throttle Cable Replacement **Now In Progress** :)   Sep 12 2016, 12:11 PM
ThinAir   That's about it. It sounds much more complicat...   Sep 12 2016, 12:16 PM
JustinMeier   Work just cleaned out the back warehouse so I have...   Sep 12 2016, 12:28 PM
Chris914n6   Wouldn't hurt to get a new ball connector, I p...   Sep 12 2016, 01:28 PM
JustinMeier   Wouldn't hurt to get a new ball connector, I ...   Sep 12 2016, 02:15 PM
Toast   :agree: That ball connector did seem pretty loose...   Sep 12 2016, 01:50 PM
Toast   The connector in the back that I showed you seemed...   Sep 12 2016, 02:43 PM
JustinMeier   I went back at lunch and looked a bit more.. Its g...   Sep 12 2016, 02:51 PM
Chris914n6   The cable slid easy enough when we had it disconne...   Sep 12 2016, 04:21 PM
JustinMeier   Bump for edit.   Sep 12 2016, 08:26 PM
injunmort   how did the cable get anywhere near the exhaust? i...   Sep 12 2016, 08:31 PM
Chris914n6   ^^ -6 not 4   Sep 12 2016, 08:48 PM
brant   :(   Sep 12 2016, 09:04 PM
JustinMeier   Justin. How do the pedals feel when the cable is...   Sep 12 2016, 09:20 PM
Toast   We didn't.. I've learned my lesson on thi...   Sep 12 2016, 11:39 PM
JustinMeier   Don't beat yourself up Justin. We all learn....   Sep 13 2016, 09:21 AM
injunmort   your point being?   Sep 12 2016, 09:07 PM
JustinMeier   .   Sep 12 2016, 09:56 PM
The Cabinetmaker   Uh, timing cover gaskets? The timing cover is just...   Sep 13 2016, 02:01 PM
Toast   Uh, timing cover gaskets? The timing cover is jus...   Sep 13 2016, 04:10 PM
JustinMeier   Timing cover....Valve cover. Whatever. :evilgri...   Sep 13 2016, 08:40 PM
ndfrigi   Looks like those cables are the clutch and speedo ...   Sep 13 2016, 03:21 PM
JustinMeier   Looks like those cables are the clutch and speedo...   Sep 13 2016, 03:35 PM
76-914   Looks like those cables are the clutch and speed...   Sep 14 2016, 08:01 AM
Dave_Darling   This is a six-cylinder engine, Curt. They may mea...   Sep 13 2016, 03:22 PM
JustinMeier   Wooohoo.. Cable out and it is most definitely bad....   Sep 13 2016, 09:33 PM
ThinAir   Wooohoo.. Cable out and it is most definitely bad...   Sep 13 2016, 09:50 PM
sixnotfour   Its a Slits show ...   Sep 13 2016, 09:54 PM
JustinMeier   Its a Slits show ... You're going to have ...   Sep 13 2016, 10:15 PM
sixnotfour   read these 17 pages... : http://z8.invisionfree.co...   Sep 14 2016, 01:34 AM
Kansas 914   read these 17 pages... : http://z8.invisionfree.c...   Sep 14 2016, 07:45 AM
JustinMeier   read these 17 pages... : http://z8.invisionfree.c...   Sep 14 2016, 08:04 AM
Toast   read these 17 pages... : http://z8.invisionfree....   Sep 15 2016, 06:15 PM
JustinMeier   Well, there is one of the threads for ya. :D Re...   Sep 15 2016, 10:51 PM
JustinMeier   One issue.. The new cable doesn't slip around ...   Sep 14 2016, 11:51 AM
steuspeed   One issue.. The new cable doesn't slip around...   Sep 16 2016, 06:34 PM
JustinMeier   This couldn't have been the problem... Naa...   Sep 15 2016, 01:51 PM
JustinMeier   So the saga continues... :wttc: I go to spin th...   Sep 15 2016, 11:01 PM
JustinMeier   Here's the first whoops...   Sep 15 2016, 11:05 PM
The Cabinetmaker   Maybe you should let dad work on his car?   Sep 16 2016, 03:30 PM
JustinMeier   Maybe you should let dad work on his car? :lol:...   Sep 16 2016, 06:07 PM
Whitney Mic   Maybe you should let dad work on his car? Too s...   Sep 16 2016, 07:24 PM
porschetub   [quote name='The Cabinetmaker' post='2399346' dat...   Sep 18 2016, 12:41 AM
Whitney Mic   I didn't laugh at all thought that was the ...   Sep 18 2016, 01:56 AM
JustinMeier   I ordered 2 so let's see which one fits.. Ter...   Sep 16 2016, 06:50 PM
JustinMeier   Thanks for the condolences Whit! There's ...   Sep 16 2016, 09:04 PM
Toast   Well I guess that will give you a chance to fix th...   Sep 17 2016, 09:01 AM
JustinMeier   With some redneck engineering and a drill, I was a...   Sep 17 2016, 03:24 PM
The Cabinetmaker   Justin, i apologize for being inconsiderate. I ha...   Sep 17 2016, 05:48 PM
JustinMeier   Justin, i apologize for being inconsiderate. I h...   Sep 17 2016, 06:55 PM
Whitney Mic   Justin, i apologize for being inconsiderate. I h...   Sep 17 2016, 10:45 PM
porschetub   Justin, i apologize for being inconsiderate. I h...   Sep 18 2016, 01:49 AM
The Cabinetmaker   Justin, i apologize for being inconsiderate. I ...   Sep 18 2016, 06:28 AM
N_Jay   Evert time I see this thread title in the new post...   Sep 17 2016, 09:07 PM
JustinMeier   Well sorta.. this side of the door broke and fe...   Sep 18 2016, 12:28 AM
JustinMeier   Whoa there. He didn't know so there's a pa...   Sep 18 2016, 12:58 AM
76-914   Justin, I feel this is the time and place to say t...   Sep 18 2016, 08:08 AM
Toast   :agree: Kent Sometimes there is that one person t...   Sep 18 2016, 10:24 AM
JustinMeier   :agree: Toast Thank you Kent! All you guys ar...   Sep 18 2016, 10:46 AM
JustinMeier   It feels like it's binding at the firewall tub...   Sep 18 2016, 10:54 AM
17 User(s) are reading this topic (17 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 08:09 AM
