87m491 |
Member ![]() ![]() Group: Members Posts: 276 Joined: 29-July 12 From: Portland, the original! Member No.: 14,731 Region Association: North East States ![]() ![]() |
Does anyone have a preferred "shortcut" for removing the retaining "U" tab on the soft line mounts to the body? The bottom ones behind the wheels are a snap as there is plenty of remove to lever with a screwdriver or other, but the upper side which is up at the edge of the engine bay has very little maneuvering room to get a tool in, on , around.
thx Mike |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
You're replacing the hoses ?
Cut the hose off the metal fitting then use a 17mm deep socket (or is it 14mm?) with a 12" extension to turn the fitting off the 11mm nut on the brake tube. Better yet, use a "crow foot" type tubing wrench and "lean" it against the nearby wall as you turn the bigger fitting off with the ratchet and socket. Use a vise grip and a flat screwdriver to remove the spring clip first |
87m491 |
You've described how I finally got the upper hose separated perfectly. Took me a while to figure since I was replacing them, I could cut off the hose near the fitting and use a deep socket 17 instead of 1/8 turn at a time with the crows foot!.
That said, removing the retaining clip is a PITA. I thought small vise grip but precious little room, at least on the drivers side where I started and am currently stuck, but will try again as you and the previous poster mentioned. You're replacing the hoses ? Cut the hose off the metal fitting then use a 17mm deep socket (or is it 14mm?) with a 12" extension to turn the fitting off the 11mm nut on the brake tube. Better yet, use a "crow foot" type tubing wrench and "lean" it against the nearby wall as you turn the bigger fitting off with the ratchet and socket. Use a vise grip and a flat screwdriver to remove the spring clip first |
rgalla9146 |
You've described how I finally got the upper hose separated perfectly. Took me a while to figure since I was replacing them, I could cut off the hose near the fitting and use a deep socket 17 instead of 1/8 turn at a time with the crows foot!. That said, removing the retaining clip is a PITA. I thought small vise grip but precious little room, at least on the drivers side where I started and am currently stuck, but will try again as you and the previous poster mentioned. You're replacing the hoses ? Cut the hose off the metal fitting then use a 17mm deep socket (or is it 14mm?) with a 12" extension to turn the fitting off the 11mm nut on the brake tube. Better yet, use a "crow foot" type tubing wrench and "lean" it against the nearby wall as you turn the bigger fitting off with the ratchet and socket. Use a vise grip and a flat screwdriver to remove the spring clip first Try using a vise grip as shown in the photo. Rotate it and pull at the same time, not too forceful. Use some WD40 and as soon as you can see a small opening in the clip use a flat screwdriver to lever the clip off. Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 11:34 PM |
