Carb Questions, yes - I searched first... |
sdoolin |
Sep 10 2016, 02:10 PM
Member Group: Members Posts: 384 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
Building a 2056 and almost complete with it except for carb rebuilding and a few other details. Going with dual Dell 40's.
My gasket kit came with what I will call "spacers" that are used between cylinder head and FI runners. Do I (should I) use these when mounting my carb manifolds? I did not use them on a bus engine I built years and years ago and it ran well - for a very long time so I am tempted to go without them, but thought I would ask. If there is significant good reason to use them, where do I find the seemingly very (very) thin gaskets that go on each side of them (head side & manifold side)? I ordered intake manifolds from Pelican but them seem a bit thick (I can use them if I choose not to use the "spacers"). Also have a few questions about accelerator cable and carb base plates. Can I re-use the cable that is in the car (it was injected and ran well)? If yes, is there an "off the shelf" bracket to mount it on the engine such that it operates the cross bar linkage? And finally (for now) does the cross bar linkage go on the front or back of the carbs (depending on base plate orientation)? Pics of your carb'ed set-up might really help me out here so if you got 'em, please feel free to use 'em. |
rhodyguy |
Sep 20 2016, 05:58 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,198 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Sorry. Idle Air Mixture Screw. They only require a light touch when seating them at the initial baseline setting and later when you are trying to achieve best lean idle. As for extra o-rings, they're cheap and it's easier than ordering out more if you have a problem or loose one.
Lo-Fi Version | Time is now: 6th January 2025 - 07:15 PM |
