> Carb Questions, yes - I searched first...
sdoolin
post Sep 10 2016, 02:10 PM
Building a 2056 and almost complete with it except for carb rebuilding and a few other details. Going with dual Dell 40's.
My gasket kit came with what I will call "spacers" that are used between cylinder head and FI runners. Do I (should I) use these when mounting my carb manifolds? I did not use them on a bus engine I built years and years ago and it ran well - for a very long time so I am tempted to go without them, but thought I would ask.
If there is significant good reason to use them, where do I find the seemingly very (very) thin gaskets that go on each side of them (head side & manifold side)? I ordered intake manifolds from Pelican but them seem a bit thick (I can use them if I choose not to use the "spacers").
Also have a few questions about accelerator cable and carb base plates. Can I re-use the cable that is in the car (it was injected and ran well)? If yes, is there an "off the shelf" bracket to mount it on the engine such that it operates the cross bar linkage? And finally (for now) does the cross bar linkage go on the front or back of the carbs (depending on base plate orientation)?
Pics of your carb'ed set-up might really help me out here so if you got 'em, please feel free to use 'em.
sdoolin
post Sep 22 2016, 06:03 AM
QUOTE(rhodyguy @ Sep 21 2016, 02:44 PM) *
3 thousands. P.3 if you have the dellorto superformance book by Tomlinson.
Yes, using the Tomlinson book. Page 3 it is, thanks as always..
sdoolin   Carb Questions   Sep 10 2016, 02:10 PM
N_Jay   They cut down the heat that gets to the carbs.   Sep 10 2016, 02:17 PM
r_towle   Hi, So the phenolic spacers helps to prevent the h...   Sep 10 2016, 02:17 PM
Ansbacher   I used spacers on a 356SC engine with Solex carbs ...   Sep 10 2016, 02:28 PM
era vulgaris   Use the spacers. I also have Dell 40's on my ...   Sep 10 2016, 05:53 PM
Localboy808   Interesting discussion. Brings up a question. Does...   Sep 10 2016, 10:43 PM
sdoolin   Thanks for the replies. I'm going to use the...   Sep 11 2016, 06:35 AM
anderssj   My linkage is towards the front of the engine--not...   Sep 11 2016, 06:31 PM
Vacca Rabite   That said, I'm seriously considering going ...   Sep 22 2016, 08:17 AM
sdoolin   If you haven't installed new ball ends onto th...   Sep 18 2016, 12:46 PM
sdoolin   Getting ready to rebuild carbs for my 2056. Carbs ...   Sep 18 2016, 12:52 PM
mobymutt   They also have some strange base plates that I h...   Sep 18 2016, 03:34 PM
anderssj   Getting ready to rebuild carbs for my 2056. Carbs...   Sep 18 2016, 03:43 PM
Elliot Cannon   I have had the hex bar linkage on my car for 13 ye...   Sep 18 2016, 01:48 PM
sdoolin   Interesting about the Dell Doctor kits - thanks fo...   Sep 19 2016, 06:51 AM
mobymutt   Mobymutt your engine looks like a fire extinguish...   Sep 19 2016, 06:40 PM
Elliot Cannon   Interesting about the Dell Doctor kits - thanks f...   Sep 19 2016, 07:15 PM
sdoolin   Calling all Dell/Carb gurus. The rebuild guide and...   Sep 19 2016, 06:43 PM
anderssj   Calling all Dell/Carb gurus. The rebuild guide an...   Sep 19 2016, 07:49 PM
cuddyk   I had a hex bar setup and phenolic spacers on my 2...   Sep 19 2016, 07:48 PM
sdoolin   Yes Elliot, thanks for the pics. I am going to hav...   Sep 20 2016, 06:20 AM
rhodyguy   You need the little dished washers/caps.   Sep 20 2016, 08:41 AM
sdoolin   You need the little dished washers/caps. Yep, m...   Sep 20 2016, 09:37 AM
sdoolin   I have reached out to Blackline Racing to see if t...   Sep 20 2016, 01:42 PM
rhodyguy   If you can, plug it in a reversible fashion. Exami...   Sep 20 2016, 02:00 PM
sdoolin   Thanks rhodyguy, I understand "plug it in a r...   Sep 20 2016, 04:36 PM
rhodyguy   Sorry. Idle Air Mixture Screw. They only require a...   Sep 20 2016, 05:58 PM
sdoolin   Ah, si comprendo now. Light touch is all that is r...   Sep 21 2016, 05:52 AM
sdoolin   Another question - I swore that the Dellorto Super...   Sep 21 2016, 11:45 AM
rhodyguy   3 thousands. P.3 if you have the dellorto superfor...   Sep 21 2016, 12:44 PM
sdoolin   3 thousands. P.3 if you have the dellorto superfo...   Sep 22 2016, 06:03 AM
anderssj   Hope these help! Page 1:   Sep 22 2016, 10:48 AM
anderssj   Page 2:   Sep 22 2016, 10:49 AM
sdoolin   Very helpful, thanks for uploading. Much easier on...   Sep 22 2016, 12:06 PM
anderssj   Very helpful, thanks for uploading. Much easier o...   Sep 22 2016, 01:18 PM
anderssj   Give these guys a try--they were a big help when d...   Sep 22 2016, 01:01 PM
stugray   http://www.dellortoshop.com/index.html   Sep 22 2016, 07:13 PM
CCE   Building a 2056 and almost complete with it excep...   Aug 22 2024, 05:48 PM
Literati914   Lets bring back very old posts on carb questions...   Aug 23 2024, 04:57 PM
- Lo-Fi Version Time is now: 6th January 2025 - 07:16 PM
