Oil pressure relief valve. |
Keith914 |
Sep 23 2016, 10:21 AM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
To the "brain trust". Two experienced engineer/mechanics have described the following:
When our Type IV engines are at operating temperature and rpm's exceed about 3,000 the pressure relief valve (ball bearing valve seen in the oil filter bracket) opens up and prevents or reduces oil flow through the filter. Thus, this reduces oil flow through external oil coolers attached via a "pancake" to the engine, greatly reducing there cooling effect when needed most, e.g. at the track. They have altered this valve so that it cannot open, and advised to keep rpm's low until the engine is warmed up -- particularly in cold climates. there are various ways to "plug" this valve, easy when removed from the engine, -- drill and thread a bolt with lock nut to hold the ball bearing closed, press in an aluminum plug, etc. Two questions: 1) are there other (than too high an oil pressure with cold engine with higher rpm's) unintended consequences, and 2) can this valve be "plugged" and how, without removing the engine to get at it? |
Keith914 |
Sep 24 2016, 12:40 PM
Thanks for the input and flow diagrams.
It is clear from the flow diagrams that the filter relief valve has the ability to reduce the flow to an outside in series filter and cooler that is connected directly to the stock oil filter console. This confirms the explains the experienced advice. Unfortunately it is also clear that while there are several ways to eliminate this by pass valve function, they require removing the engine to either; 1) access the upper oil filter console nut to remove the console for modification, or 2) to connect the external filter/cooler system to the galley plugs next to the oil pump. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:41 AM |
