> BUILD-OFF CHALLENGE: Stacks914, Might be part of a build off????
Stacks914
post Sep 19 2015, 02:08 AM
Ok guys I am posting picks of building my car. I have about three days maybe 12 hours total on this Build of actual of the car. I am in a build off.... So here are pics of the car and what I have been doing. I am really just currently deconstructing. The build will have a corvette c6 front and C5 rear suspension and a tube chassis, and c5 z06 rims that are 17/18. The powertrain I have is a 5.3 out of an 04 silverado. the trans is a boxster S unit. I also have a 70mm turbo for the engine. I have purchased but am still waiting on the adapter. Will probably be extending the rear of the car at least 5-8 inches as I would like to use the stock accesorys. or I would like to keep the power streering pump at least and the alternator. I am a bigger guy and really cannot sacrifice any room inside. Plus I would like a nice stereo in there(and a hot woman). And that is about it. I am just a one man operation building this car out of his garage. I do not own a shop. I will be doing all of the work myself or as much as possible. I realize I am in a build off but really this is cheap entertainment for me. So please lets keep it entertaining. Currently in Omaha NE and no one knows what this car is. but they do think its cute and want one...lol. I have not seen one of these on the road in years. I have 2. This red one I bought with the intentions of flipping and making some quick money. After about 6 weeks of trying to sort out the engine my patience and money I had allocated for this car was done. So it became the focus of the build only becuase it was titled in Ne and would not have go through inspection. I realize I am in way over my head here (IMG:style_emoticons/default/wink.gif) thats where i am comfortable. The welding on the car will be conducted by a local professional that works on nuclear reactors until I am comfortable I can do it but its really not that hard and I am getting better. While I am currently on 31 total hours of work time. I have about 6 months of research into the car putting together a broad stroke design and I do not have every aspect of this car figured out in my head. I deal with the details as they arise! this might seam maddning to some of you but please bare with me!
The details I have not figured out yet are! Yes I realize some of this stuff is a few hours google searching.
Wiring harness: I have spent alot of time rewiring some of the factory porsche unit! I would like to ditch and update the whole thing! Anyone know a good one I could buy that will run the lights, engine, radio, and maybe a hvac system one day. Or at least an updated fuse boxe and I will wire and soldier one together? Would like to stay in the $400 range
Boxster Trans: I really have a bare boxster trans I do not know what it takes to get it shifting entirely in my car, or how much it will cost?
Radiator with fans: I have not found one yet or looked too deaply into this. When I get closer to needing it which will be soon I will. I just need the radiator I am not buying a kit? I see these pop up for a vette on craigs sometimes. really like the Factory 5 gtm install of these thoughts opinions? Dollar figure?
Intercooler: I just haven't bought one and the tubing yet
ECU: the fianl tuning willl be done by a professinal shop with dyno
Fender Flares: I really like the plastic/riveted on look! Love liberty walk stuff!!
Rear axles: will need porsche to corvette hubs
methanol kit/80#injectors/bosche 044 fuel pump/tires/5 point belts/600hp rated clutch
probably will stuff at least 7 speakers into the car
The whole engine build is a few months away! though I might scrap the turbo system and build a destroked ls engine that revs as it would be more suited to the boxster trans either way 500whp should be attainable. I just love high revving engines but boost builds power cheap
My toying with a dream additions (probably not going to make it)
keyless push buttom start/power windows/locks
Vintage heat and A/C
Ring and pinion swap/lsd for trans
My budgete is about 2-300 a week on top of what I have bought!
Stacks914
post Sep 28 2016, 01:10 AM
I think I might be able to get away with 3 inch flares on either side. The track is 72 inches with 305 35 18 nitto nt1. So maybe an expert can chime in? Also have engine semi prepped need to take off truck harmonic balancer and add the corvette one I have. Have intake off that needs to be flipped and f body oil pan needs put on and turbo drain feed drilled. So really the 2 days I spent getting the stuck in header bolts off and trying to find a decent pair of heads. That is semi prepped I guess. The f body oil pan is is only 5 inches deep compared with the 9 inch truck pan. Dry sump was considered but cost was too great. About just trashed the 5.3 and bought a 6.0 due to heads but the 100 bucks it drill bits saved the day. As the screw removers got stuck in two bolts and broke off. Which blows or blew as getting them out was a nightmare. Plus the 5.3 will put out more than enough power for the boxster trans. Which when c8 comes out will probably get replaced with that trans.
Stacks914   BUILD-OFF CHALLENGE: Stacks914   Sep 19 2015, 02:08 AM
Stacks914   Taking apart   Sep 19 2015, 02:11 AM
Stacks914   Got my steal today! and then realized I got t...   Sep 19 2015, 02:18 AM
Stacks914   Had two hours this morning...14 total.   Sep 19 2015, 01:58 PM
Stacks914   Spent three more hours today of actual work. Thre...   Sep 21 2015, 07:40 PM
Stacks914   So at 19 hours total of actual work I am at this p...   Sep 21 2015, 10:32 PM
Stacks914   Yea ssssuckaaa...Lol 23 hours total. :sawzall:   Sep 24 2015, 08:21 PM
Jeff Bowlsby   What the paint code of your car...in some of the p...   Sep 25 2015, 02:04 PM
r_towle   You must be young....   Sep 25 2015, 03:17 PM
Chris914n6   You must be young.... and too excited to hold th...   Sep 26 2015, 09:40 PM
rhodyguy   Any idea of the purpose of removing most of the tr...   Sep 26 2015, 12:38 PM
Stacks914   The paint code is L31M looks like it was resprayed...   Sep 26 2015, 01:38 PM
Jeff Bowlsby   L31M? Scarlet Red...that's painful.   Sep 26 2015, 01:45 PM
AndyB   L31M? Scarlet Red...that's painful. :agree...   Oct 4 2015, 05:48 AM
quadracerx   If you ever want to race this car, I would recomme...   Sep 26 2015, 03:24 PM
Stacks914   Steve thank you for the input I never even thought...   Sep 26 2015, 09:00 PM
quadracerx   I hope you double check the rules for both NHRA Dr...   Sep 26 2015, 09:42 PM
Stacks914   Oh I am actually 37 the shakiness is from the thir...   Sep 26 2015, 10:10 PM
Stacks914   Will it fall in half?   Sep 26 2015, 10:12 PM
Stacks914   Got a call today and c6 front already here   Sep 28 2015, 04:21 PM
scotty b   I don't mean to be offensive or tell you what ...   Sep 28 2015, 04:33 PM
Mikey914   As long as you can verify the points as per the ma...   Sep 28 2015, 04:47 PM
Stacks914   I don't mean to be offensive or tell you what...   Sep 29 2015, 12:27 AM
Olympic 1.7   [quote name='scotty b' post='2244517' date='Sep 2...   Sep 29 2015, 06:06 AM
scotty b   [quote name='scotty b' post='2244517' date='Sep 2...   Sep 29 2015, 06:38 AM
Cairo94507   :popcorn: :popcorn: :popcorn: :popcorn: :confu...   Sep 29 2015, 06:49 AM
Stacks914   Scott I am sorry I am sure you are a valuable asse...   Sep 29 2015, 02:02 PM
trojanhorsepower   :Qarl: I applaud you both. It is so refreshing to...   Sep 29 2015, 04:48 PM
Stacks914   Update Eric@kitcarchassis.com has been in contact ...   Oct 1 2015, 01:08 AM
mbseto   ...I get cranky when assumptions are made. The ...   Oct 2 2015, 07:41 AM
Stacks914   Hey motherfucker I know everything there is to kno...   Oct 2 2015, 12:42 PM
Andyrew   Would you mind updating your first post to include...   Oct 2 2015, 10:33 AM
Mueller   Oh boy, that is going to be a lot of work...I love...   Oct 2 2015, 11:18 AM
Stacks914   This is from the front Ok guys I am posting pick...   Oct 2 2015, 12:37 PM
Stacks914   Cleaning out garage today weighing some things 72...   Oct 3 2015, 02:20 AM
rgalla9146   Do you have health insurance ?   Oct 4 2015, 07:03 AM
Stacks914   Do you have health insurance ? of course why wo...   Oct 4 2015, 10:36 AM
Porschef   :shades2: :popcorn: :blink:   Oct 4 2015, 07:28 AM
Stacks914   Today I am spending it chasing my buddy who has a ...   Oct 4 2015, 12:27 PM
Stacks914   Got a power assisted steering column from an 05 eq...   Oct 6 2015, 11:13 AM
Stacks914   Got a power assisted steering column from an 05 eq...   Oct 6 2015, 11:37 AM
Stacks914   http://www.ebay.com/itm/Saturn-Vue-Ion-Che...818...   Oct 6 2015, 12:57 PM
Stacks914   And if the 914 gods where not shining on me enough...   Oct 6 2015, 01:32 PM
Stacks914   And if the 914 gods where not shining on me enough...   Oct 6 2015, 01:34 PM
Stacks914   Well it's been a few days of this is shit and ...   Oct 10 2015, 07:12 PM
Stacks914   Only a few hours today got front a arm supports st...   Oct 11 2015, 08:06 PM
Mueller   Neat PS controller.... For the suspension, how do...   Oct 11 2015, 10:38 PM
Stacks914   Thank you the bottom of the ps column fits right o...   Oct 12 2015, 01:59 AM
Stacks914   i just want something like this........ :headbange...   Oct 12 2015, 02:09 AM
Stacks914   An idea   Oct 12 2015, 04:27 AM
Stacks914   Well this is the second time doing the passenger a...   Oct 19 2015, 11:09 PM
Mr.C   Take a look at the Locost 7 builds on google. The...   Oct 19 2015, 11:25 PM
Stacks914   Lmao thanks will do! I do like that site. I...   Oct 20 2015, 01:54 AM
Mr.C   Yeah, Locost 7 builds get my blood flowing, lots o...   Oct 21 2015, 12:22 PM
Stacks914   Ok the front is almost done. Took A LONG time of ...   Oct 28 2015, 09:06 PM
stevegm   Stacks914, please PM me. We need some info from yo...   Nov 6 2015, 08:17 AM
Stacks914   Pm sent Steve!! Also if anyone has a clev...   Nov 13 2015, 04:52 PM
rick 918-S   Ambitious build. Keep at it! :welder:   Jan 31 2016, 11:15 PM
Stacks914   Anyways this project is back on....currently. I r...   Sep 28 2016, 12:49 AM
Stacks914   You can see in the last picture I have bent the re...   Sep 28 2016, 12:54 AM
Stacks914   Here suspension is put this under the car to get a...   Sep 28 2016, 12:58 AM
Stacks914   I think I might be able to get away with 3 inch fl...   Sep 28 2016, 01:10 AM
mbseto   Impressive footprint.   Sep 28 2016, 02:25 PM
timothy_nd28   Eric is a good guy and does awesome work, but he...   Sep 28 2016, 02:57 PM
Stacks914   Eric is a good guy and does awesome work, but he...   Sep 29 2016, 10:25 PM
Stacks914   Thanks mbesto and Tim I am not sure exactly how it...   Sep 28 2016, 08:12 PM
Stacks914   Here I got a little over zealous with the sawzall....   Sep 28 2016, 08:53 PM
Stacks914   With a sawzal you can do anything   Sep 29 2016, 07:54 PM
Stacks914   Just allow me to stuff this in there....   Sep 29 2016, 07:56 PM
Stacks914   This is when you just stare for 2 hours wondering ...   Sep 29 2016, 07:57 PM
Stacks914   It's getting lower   Sep 29 2016, 07:59 PM
Stacks914   Here is am getting an ides of the well that I need...   Sep 30 2016, 11:58 PM
Stacks914   In the land of coulda, shoulda, woulda I would hav...   Oct 1 2016, 12:34 AM
Stacks914   Then to remeasure and wonder what the fuck you whe...   Oct 1 2016, 02:04 PM
Stacks914   Though this car has the Brad Meyer kit it's we...   Oct 2 2016, 03:29 PM
Stacks914   This harmonic balancer took about 8 hours total to...   Oct 5 2016, 12:50 AM
KevinW   PM sent   Oct 5 2016, 05:47 AM
- Lo-Fi Version Time is now: 3rd April 2025 - 01:33 AM
