What is this switch under the dash? |
surfdogskier |
Oct 4 2016, 01:25 PM
Member Group: Members Posts: 164 Joined: 20-May 16 From: East TN Member No.: 20,019 Region Association: None |
I have no idea what this is or does. I can't find anything on it. It is a turning switch with a wire attached to it. I havent tore my dash apart yet to figure out where it goes. It is a turn style switch. I wondered if it was some type of kill switch since I can't start my car for the life of me. Do any of you have this or is this stock?
Attached image(s) |
db9146 |
Oct 4 2016, 01:32 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Its the odometer reset. Twist it and it rolls through all of the digits on the odometer to reset it to "0000".
malcolm2 |
Oct 5 2016, 02:38 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Its the odometer reset. Twist it and it rolls through all of the digits on the odometer to reset it to "0000". "0000" if you are lucky..... mine stops on 0010 every damn time. drives me crazy. And mine is not attached to the btm of the dash. Some PO pulled it out and re-installed the nut (that rusted) so mine just dangles, never to be attached again. |
TheCabinetmaker |
Oct 5 2016, 04:55 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Its the odometer reset. Twist it and it rolls through all of the digits on the odometer to reset it to "0000". "0000" if you are lucky..... mine stops on 0010 every damn time. drives me crazy. And mine is not attached to the btm of the dash. Some PO pulled it out and re-installed the nut (that rusted) so mine just dangles, never to be attached again. Just pull it out of the back of the Speedo can. Its just poked in a hole. Unrust it, and stick it back in. (IMG:style_emoticons/default/beer3.gif) |
Lo-Fi Version | Time is now: 18th June 2024 - 06:35 AM |
