> Go Big or Go Home: Clay's 914-6, MS3Pro Wiring in Progress
Should I paint the flat fan shroud?
Paint or not
Paint it Red to match the car [ 15 ] ** [23.81%]
Paint it some other color. [ 3 ] ** [4.76%]
Leave it the current amber fiberglass color [ 45 ] ** [71.43%]
Total Votes: 63
Guests cannot vote
ClayPerrine
post Mar 17 2016, 08:54 PM
It begins:
Just arrived from Hawaii...
3.6L 964 motor. Destined to become a 4.0L with 993 RS cams. I am keeping the FI so it is a bit more drivable than the MFI motor I have now.
I actually started this years ago. I bought a 3.6, but it turned out to be unusable. But I had already bought the LN engineering pistons, cylinders, rods and stud kit to make it a 4.0. So now I get to use all that stuff!.
rgalla9146
post Oct 3 2016, 09:29 PM
Is the end of the cam visible in front of the oil cooler ?
Shouldn't there be a cap there ?
ClayPerrine
post Oct 5 2016, 11:55 AM
QUOTE(rgalla9146 @ Oct 3 2016, 10:29 PM) *
964/993 motors don't have engine mounted oil coolers
The motor originally had a power steering pump drive there. I intend to fabricate an AC compressor mount for the same location.
Mark Henry
post Oct 9 2016, 02:20 PM
that's what I do!
QUOTE(ClayPerrine @ Oct 5 2016, 01:55 PM) *
On my engine I'm using 993 cams, I cut that drive off to use a stock cooler. I also modified the cam nose to accept regular 911 cam sprockets. Had to weld them up and grind in a woodruff key slot.
No more funky 993 sprockets that take $1+k worth of tools to do the cam timing.
ClayPerrine   Go Big or Go Home: Clay's 914-6   Mar 17 2016, 08:54 PM
whitetwinturbo   :popcorn: :popcorn: :popcorn:   Mar 17 2016, 10:00 PM
Andyrew   Build off challenge? That being said Im looking ...   Mar 17 2016, 10:11 PM
RobW   4.0 Porsche motor in a 914...... :D :D :D :D ...   Mar 17 2016, 11:10 PM
396   Yes,4.0 :popcorn: :popcorn: :popcorn:   Mar 18 2016, 04:13 AM
914forme   :popcorn:   Mar 18 2016, 05:06 AM
stevegm   Interesting engine build. Are you planning to do t...   Mar 18 2016, 07:26 AM
ClayPerrine   Interesting engine build. Are you planning to do ...   Mar 18 2016, 09:17 PM
ClayPerrine   Interesting engine build. Are you planning to do...   Mar 19 2016, 06:48 AM
theleschyouknow   :trophy: sweet glad you found one! let me kno...   Mar 18 2016, 11:13 AM
Mueller   Dang...that will be a fun motor! I figured o...   Mar 18 2016, 11:22 AM
Mark Henry   :thumbsup:   Mar 18 2016, 11:24 AM
porschetub   It begins: Just arrived from Hawaii... ...   Mar 18 2016, 11:38 AM
ClayPerrine   Great find,had the original car suffered from an...   Mar 18 2016, 01:15 PM
naro914   I plan on using a Boxster 6 speed for a transmiss...   Mar 18 2016, 02:49 PM
396   If you're going to install factory 993RS cams....   Mar 18 2016, 02:57 PM
ClayPerrine   [quote name='ClayPerrine' post='2317410' date='Ma...   Mar 18 2016, 09:15 PM
Mueller   [quote name='ClayPerrine' post='2317410' date='M...   Mar 18 2016, 11:09 PM
naro914   [quote name='naro914' post='2317436' date='Mar 18...   Mar 20 2016, 10:23 AM
ClayPerrine   A little gratuitous engine porn: http://www.914wo...   Mar 18 2016, 09:27 PM
tomrev   A little gratuitous engine porn: http://www.914w...   Mar 19 2016, 08:45 AM
kid914   4.0 ? :woohoo: I thought of doing this awhile bac...   Mar 19 2016, 08:23 AM
PanelBilly   Details, I want all the details of what you've...   Mar 19 2016, 10:30 AM
whitetwinturbo   :popcorn: :popcorn: :popcorn: ........all in f...   Mar 19 2016, 08:23 PM
Rob-O   Looks fantastic, can't wait to see this come t...   Mar 19 2016, 09:49 PM
r_towle   Great project, good luck this time around.   Mar 19 2016, 10:59 PM
thelogo   4.0 in 914 You must have alot Of Driveing skil...   Mar 20 2016, 12:03 AM
ClayPerrine   An screw the boxter six speed and How to instal...   Mar 20 2016, 06:42 AM
JmuRiz   Why would you want the 7-speed? It's only ther...   Mar 20 2016, 08:17 AM
Catorse   Clay what kind of power can you get out of a built...   Mar 20 2016, 09:49 AM
mepstein   Clay what kind of power can you get out of a buil...   Mar 20 2016, 10:18 AM
Catorse   Clay what kind of power can you get out of a bui...   Mar 20 2016, 11:58 AM
mepstein   [quote name='mepstein' post='2318224' date='Mar 2...   Mar 20 2016, 12:22 PM
ClayPerrine   [quote name='mepstein' post='2318224' date='Mar ...   Mar 20 2016, 06:34 PM
396   Clay what kind of power can you get out of a bui...   Mar 25 2016, 08:18 PM
SirAndy   Mark, after reading your post of 325 -350 hp. I h...   Mar 25 2016, 08:26 PM
Mueller   [quote name='mepstein' post='2318224' date='Mar 2...   Mar 25 2016, 08:27 PM
mepstein   [quote name='mepstein' post='2318224' date='Mar 2...   Mar 25 2016, 09:03 PM
396   [quote name='mepstein' post='2318224' date='Mar ...   Mar 25 2016, 09:33 PM
ClayPerrine   Im no expert but when you: Tune the exhaust Rais...   Mar 27 2016, 06:46 AM
mepstein   Im no expert but when you: Tune the exhaust Rai...   Mar 27 2016, 07:05 AM
ClayPerrine   The weekend progress:   Mar 20 2016, 06:40 PM
billh1963   The weekend progress: Ugly on the outside but...   Mar 20 2016, 06:42 PM
ClayPerrine   The weekend progress: Ugly on the outside bu...   Mar 20 2016, 06:49 PM
mepstein   [quote name='billh1963' post='2318378' date='Mar ...   Mar 20 2016, 07:03 PM
ClayPerrine   [quote name='billh1963' post='2318378' date='Mar...   Mar 20 2016, 07:17 PM
ClayPerrine   Update.. no pictures. Cases are stripped, includi...   Mar 24 2016, 01:57 PM
Rob-O   Looks like the tear down is coming along quick. H...   Mar 24 2016, 02:52 PM
Rob-O   I got a peek at the rods and pistons yesterday. P...   Mar 27 2016, 07:51 AM
ClayPerrine   Heads, case halfs and one cylinder went to the mac...   Mar 30 2016, 04:33 PM
396   Congrats with your progress. Quick question, sin...   Mar 30 2016, 05:45 PM
ClayPerrine   Congrats with your progress. Quick question, si...   Mar 30 2016, 06:30 PM
76-914   :bump:   Mar 31 2016, 08:13 AM
ClayPerrine   Update: Went to the machine shop today. They stil...   Jun 3 2016, 06:21 PM
ClayPerrine   I got the engine cases back, and started assemblin...   Jul 2 2016, 01:08 PM
Mueller   Nice motor there.... and OUCH, small world, I too...   Jul 2 2016, 01:14 PM
Rob-O   Sorry to hear about the finger. But the assembly ...   Jul 2 2016, 01:25 PM
theleschyouknow   looking good clay! sorry bout your finger :b...   Jul 2 2016, 01:33 PM
veekry9   :evilgrin: Seven stitches. <_< As a remind...   Jul 2 2016, 03:46 PM
ClayPerrine   :evilgrin: Seven stitches. <_< As a remin...   Jul 2 2016, 04:09 PM
veekry9   I have a similar scar,same finger,missed the tendo...   Jul 3 2016, 04:25 PM
ClayPerrine   I have not updated this thread in a while. But ...   Oct 1 2016, 12:02 PM
raynekat   Big no on the red paint. Keep it as much factory l...   Oct 1 2016, 12:30 PM
mepstein   Big no on the red paint. Keep it as much factory ...   Oct 1 2016, 12:37 PM
914forme   Clear them Paint or Powdercoat the engine tin, un...   Oct 1 2016, 12:30 PM
ClayPerrine   Clear them Paint or Powdercoat the engine tin, u...   Oct 1 2016, 12:48 PM
Maltese Falcon   [quote name='914forme' post='2405670' date='Oct 1...   Sep 8 2017, 03:37 PM
ClayPerrine   [quote name='914forme' post='2405670' date='Oct ...   Sep 8 2017, 09:24 PM
Rob-O   Awesome.   Oct 1 2016, 01:03 PM
bandjoey   You don't need that finger with that Big moto...   Oct 1 2016, 01:14 PM
whitetwinturbo   ................size matters :beer3: :beer3: :b...   Oct 3 2016, 08:42 PM
rgalla9146   Is the end of the cam visible in front of the oil ...   Oct 3 2016, 09:29 PM
ClayPerrine   Is the end of the cam visible in front of the oil...   Oct 5 2016, 11:55 AM
Mark Henry   Is the end of the cam visible in front of the oi...   Oct 9 2016, 02:20 PM
Perry Kiehl Clone   Paint the valve covers black and sand off the ribs...   Oct 3 2016, 09:49 PM
ClayPerrine   Paint the valve covers black and sand off the rib...   Oct 5 2016, 01:04 PM
ClayPerrine   New picts of progress Clewett 964 Serpentine bel...   Oct 7 2016, 07:25 PM
Rob-O   I believe Betty. I know I'd be making vroom v...   Oct 7 2016, 07:46 PM
ClayPerrine   I believe Betty. I know I'd be making vroom ...   Oct 7 2016, 09:07 PM
Cracker   Get that thing on the road Clay...even better, to ...   Oct 8 2016, 06:03 AM
ClayPerrine   I am at work this morning, so I don't have pic...   Oct 9 2016, 06:51 AM
Dave_Darling   Good ideas! Sounds like this is going to be a...   Oct 9 2016, 01:51 PM
ClayPerrine   Good ideas! Sounds like this is going to be ...   Oct 9 2016, 07:35 PM
Dave_Darling   If you are EVER near my car, I am going to carry ...   Oct 10 2016, 04:53 PM
Cracker   :rotfl:   Oct 10 2016, 05:13 PM
ClayPerrine   Are you sure you can hold the cardboard up high...   Oct 10 2016, 07:23 PM
Ferg   Do I spy a Pulsar? :Qarl:   Oct 9 2016, 02:00 PM
ClayPerrine   Do I spy a Pulsar? :Qarl: Yep... Good Eye. I...   Oct 9 2016, 07:49 PM
Ferg   Here was mine, found 2 years ago. Same deal low m...   Oct 10 2016, 02:02 PM
rhodyguy   Those GTiRs are pretty cool. The AWD version must ...   Oct 10 2016, 06:49 PM
ClayPerrine   Today was "Arts and Crafts" day.... I m...   Oct 15 2016, 05:48 PM
ClayPerrine   Did some work on the left heater box. Transferrin...   Oct 16 2016, 06:21 PM
ClayPerrine   Well... this hasn't been updated for a while. ...   Sep 5 2017, 06:39 PM
Rob-O   Impressive work, Clay. I can't wait to see th...   Sep 5 2017, 08:48 PM
jesse7flying   I always marvel at the inventiveness of the folks ...   Sep 6 2017, 03:15 PM
burton73   Hi Clay, Why did you not just use a Boxster shift...   Sep 8 2017, 09:35 PM
ClayPerrine   Hi Clay, Why did you not just use a Boxster shif...   Sep 8 2017, 09:43 PM
partsguy22   :D I am enabling Clays bad ideas in the form of ma...   Mar 27 2018, 09:07 AM
mb911   Did this trans ever get completed. I would love a...   Mar 27 2018, 03:54 PM
Luke M   :popcorn: ... Great now I need one of these too.. ...   Mar 27 2018, 05:16 PM
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 3rd April 2025 - 08:33 PM
