Converting a Vanagon TB for use with 1.8 L-Jet, How I did it |
MrKona |
Nov 2 2014, 08:36 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
There's currently a thread about using L-jet from a 1.8L engine for a 2.0 with discussion about using bigger bore throttle body from a later Vanagon.
I tried it but ran into an issue with the orientation of the flat on the shaft that engages the throttle body switch component used with L-Jet. Pictures are worth a thousand words, so here goes.. Here's the TPS and a picture of each TB with the plate in the throttle closed position. Original 1.8 L-jet on the right, Vanagon donor TB on the left. Notice the different orientation of the flat on the shafts. The flat engages a corresponding flat on the TPS. The flat on the Vanagon shaft is in the wrong position for the TPS. Attached image(s) |
aerokurt |
Oct 9 2016, 05:14 PM
Newbie Group: Members Posts: 3 Joined: 3-January 14 From: Reston, Va., Wrightwood, Ca., Member No.: 16,832 Region Association: MidAtlantic Region |
How about trying one from an Alfa spider from 1982 and onwards. L-jet too and 140 hp.
I have not yet, but will when the next Alfa comes in the shop. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:09 AM |
