> New member, 1972 does not stop
acebee
post Oct 3 2016, 10:39 PM
Hi Forum Members
Just joined the forum today..this is my first post on the 914world...
please forgive if this is not the correct place to ask the question..
i had purchased a 1972 ( Dec 1971 build on the data strike plate ) and have used it for an year without any problem..
It has a 1600 or 1700 cc displacement..not sure which..with dual webber 40 IDA setup with computune & pertronix coil for ignition
most of the electric stuff seems stock for carb setup it is .. being smog free most of the other electrical stuff was removed..like buzzer, seat belt warning et all..
the car does not stop..when i turn the ignition switch off .
i had to pull the ignition coil to dizzy cap wire & then disconnect ground from battery to stop the running facet fuel pump
seems there is electrical feedback in the system..
should i have to replace the ignition switch and the voltage regulator ( bosch stock version with the yellow tape ?).. does the order matter..
Is there any other gremlin.. the real culprit ?
57lincolnman
post Oct 12 2016, 10:43 PM
After two ignitions switches that both went bad, I use a starter button. I turn the ignition switch to the accessory position, put in the clutch and press the starter button. Yeah, it's a bit like starting a '49 Dodge but at least it's reliable.
acebee   New member   Oct 3 2016, 10:39 PM
ConeDodger   Ignition switches go bad. In fact the new replacem...   Oct 3 2016, 10:44 PM
ConeDodger   :wttc:   Oct 3 2016, 10:45 PM
acebee   :wttc: Thanks Cone Dodger.. I am the squirrel ...   Oct 4 2016, 09:57 AM
Dave_Darling   Fiddling with the electrical system can result in ...   Oct 3 2016, 11:12 PM
bretth   Wth? Does that mean someone could start a 914 with...   Oct 4 2016, 06:50 AM
Cuda911   Wth? Does that mean someone could start a 914 wit...   Oct 4 2016, 09:06 AM
mgp4591   Wth? Does that mean someone could start a 914 wi...   Oct 13 2016, 03:16 AM
euro911   Fiddling with the electrical system can result in ...   Oct 13 2016, 03:00 AM
falcor75   Start the car and turn it off again, then when it ...   Oct 3 2016, 11:14 PM
Shadowfax   :wttc:   Oct 4 2016, 09:45 AM
acebee   :wttc: Thanks..   Oct 4 2016, 09:46 AM
acebee   Hi Forum Members Just joined the forum today..th...   Oct 4 2016, 09:52 AM
acebee   Confirmed on my December 1971/1972 model - press...   Oct 12 2016, 10:16 PM
57lincolnman   After two ignitions switches that both went bad, I...   Oct 12 2016, 10:43 PM
euro911   After two ignitions switches that both went bad, I...   Oct 13 2016, 03:01 AM
euro911   :lol:   Oct 13 2016, 04:10 AM
Cairo94507   :wttc: Well at least you are in the right place to...   Oct 13 2016, 05:56 AM
Cracker   Welcome. You have an unusual problem - most of the...   Oct 13 2016, 06:59 AM
SirAndy   Welcome. You have an unusual problem - most of the...   Oct 13 2016, 11:45 AM
RobW   :wttc: :wttc: : Good luck with your 914 program...   Oct 13 2016, 07:18 AM
- Lo-Fi Version Time is now: 15th January 2025 - 07:46 AM
