> Floor Pan Coating?
dgraves
post Oct 15 2016, 09:50 AM
As I continue the refurbishment of my '74 914, I notice that the floor pan inside the car has some kind of a 3/16" protective coating. Parts of this have chipped away. Does anyone have a substitute application to patch and restore the floor pan?
Mikey914
post Oct 15 2016, 10:54 AM
The rubber man
It's basically a tar pad. They are known to have hidden and even promoted rust by holding water. Others have used Dynamat, and Home depot actually has the material inexpensively. The question is do you want to put it back in, once you have removed it.
dgraves   Floor Pan Coating?   Oct 15 2016, 09:50 AM
Mikey914   It's basically a tar pad. They are known to ha...   Oct 15 2016, 10:54 AM
dgraves   Thank you. Luckily, the car is pretty rust free a...   Oct 15 2016, 11:54 AM
BeatNavy   Do you know what was used in the areas where the ...   Oct 15 2016, 12:07 PM
jcd914   It appears that it was applied[b] right over the...   Oct 15 2016, 12:37 PM
Mikey914   If you really want to protect it, I'd have it ...   Oct 15 2016, 12:12 PM
slotty008   It's a pain to remove the tar coating . But I ...   Oct 15 2016, 01:28 PM
ndfrigi   you may see like these under tar.   Oct 15 2016, 02:24 PM
ndfrigi   RE: Floor Pan Coating?   Oct 15 2016, 02:25 PM
Mr.Nobody   What are people's thoughts on the best way to ...   Oct 15 2016, 05:06 PM
matthepcat   Heat gun and large screw driver or chisel worked f...   Oct 15 2016, 05:22 PM
stevegm   Heat gun and large screw driver or chisel worked ...   Oct 15 2016, 05:47 PM
bandjoey   $39 multi tool at Harbor Freight. It cuts the...   Oct 15 2016, 10:52 PM
draganc   $39 multi tool at Harbor Freight. It cuts th...   Oct 16 2016, 07:19 PM
cary   My .02c. Heat gun and multi-tool or air chisel. Yo...   Oct 16 2016, 06:54 AM
mepstein   My .02c. Heat gun and multi-tool or air chisel. Y...   Oct 16 2016, 07:33 AM
cary   I plan to try that on the next race car strip down...   Oct 16 2016, 07:48 AM
74ravenna   I hate to ask but does anyone know what the ...   Oct 16 2016, 08:08 AM
74ravenna   Did porsche use this method of coating on the 911s...   Oct 16 2016, 10:59 AM
cary   Did porsche use this method of coating on the 911...   Oct 16 2016, 07:44 PM
rmdinmd   As long as the fibers don't float in the air y...   Oct 16 2016, 05:22 PM
tomeric914   If you don't want to to use an adhesive backed...   Oct 16 2016, 05:35 PM
dgraves   Spectrum? Ok, I'll look into it. The tar has...   Oct 16 2016, 05:42 PM
74ravenna   Spectrum? Ok, I'll look into it. The tar ha...   Oct 16 2016, 07:18 PM
- Lo-Fi Version Time is now: 19th April 2025 - 01:09 PM
