dgraves |
1974 914 2.0 ![]() ![]() Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains ![]() |
As I continue the refurbishment of my '74 914, I notice that the floor pan inside the car has some kind of a 3/16" protective coating. Parts of this have chipped away. Does anyone have a substitute application to patch and restore the floor pan?
tomeric914 |
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,266 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States ![]() ![]() |
If you don't want to to use an adhesive backed sound sheet for fear of water entrapment, consider something like Spectrum or Spectrum Sludge
http://store.secondskinaudio.com/spectrum/ I used Spectrum on a VW Bug pan over 10 years ago and it's still going strong. I used a brush to apply multiple coats after I had completed all rust repairs and primed the pan. Definitely got rid of the tinniness of a bare metal pan. |
dgraves |
Spectrum? Ok, I'll look into it. The tar has held up well. Since reading all of these posts, I've taken samples off and have found just clean, bare metal. I guess I'm lucky.
I appreciate all of the feedback and dialogue, everyone. I'm new to 914World. Dan If you don't want to to use an adhesive backed sound sheet for fear of water entrapment, consider something like Spectrum or Spectrum Sludge http://store.secondskinaudio.com/spectrum/ I used Spectrum on a VW Bug pan over 10 years ago and it's still going strong. I used a brush to apply multiple coats after I had completed all rust repairs and primed the pan. Definitely got rid of the tinniness of a bare metal pan. |
74ravenna |
Member ![]() ![]() Group: Members Posts: 472 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States ![]() ![]() |
Spectrum? Ok, I'll look into it. The tar has held up well. Since reading all of these posts, I've taken samples off and have found just clean, bare metal. I guess I'm lucky. I appreciate all of the feedback and dialogue, everyone. I'm new to 914World. Dan If you don't want to to use an adhesive backed sound sheet for fear of water entrapment, consider something like Spectrum or Spectrum Sludge http://store.secondskinaudio.com/spectrum/ I used Spectrum on a VW Bug pan over 10 years ago and it's still going strong. I used a brush to apply multiple coats after I had completed all rust repairs and primed the pan. Definitely got rid of the tinniness of a bare metal pan. I too took off samples and found bare metal so I decided not to do the whole floor, but then I saw ndfrigi's photos and so I checked those areas. Sure enough, I found rust under the drivers side tar. Its only surface rust but I am now converted and will strip the entire floor pan. Did you look around the accelerator pedal? I noticed the rust is in the low spots/valleys. I hope you are lucky and don't have any Dan. good luck. ps.s Thanks to ndfrigi for the pictures, it was an eye opener! |
Lo-Fi Version | Time is now: 19th April 2025 - 01:07 PM |
