Localboy808 |
Member ![]() ![]() Group: Members Posts: 185 Joined: 17-July 16 From: Palmdale, Ca Member No.: 20,194 Region Association: None ![]() |
I bought a Tri-Mil 4 tip exhaust off of Craigslist. But my noob self did not know there was a difference between a 2.0 exhaust and a 1.7/1.8! Well I do now! (IMG:style_emoticons/default/wink.gif) So my question is. Can I use this exhaust with a different set of j-tubes/headers? Or is it impossible? I've been trying to sell it. But if there is a way to use it I'd like to. Could this work?
Thanks, Scott |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
Depending on what the muffler is made to fit, 73/74 2.0L or 75/76 20L, you can replace your 1.7 Heat exchangers with 2.0 heat exchangers that match your muffler.
You also have to replace the muffler bracket on the back of the trans mission. There are only 3 different exhaust systems used on 4 cyl 914s. 70-74 1.7L/1.8L system 73-74 2.0L system 75-76 2.0L system You can use any system on any car but you need the complete system, including the muffler bracket. The heater connector parts (s-tubes, j-tubes) on 70-74 are all the same, 75-76 are different. Jim |
Lo-Fi Version | Time is now: 26th June 2024 - 06:53 AM |
