Groosh |
Member ![]() ![]() Group: Members Posts: 50 Joined: 21-October 11 From: Dexter, MI Member No.: 13,702 Region Association: Upper MidWest ![]() |
Hi. I recently bought a '74 1.8 and am looking for help to get it running. It has the original fuel injection and ran late last year according the previous owner.
Here's what I know after reading many posts in the forum and working on it. Thanks to everybody who contributes, I couldn't have gotten this far without your help. - The dual relay is bad I believe. After wiring it all back up, there is power from the ignition to both the start wire and run wire but no power to the fuel pump. I'm jumping the pump currently to test - All relays in the board work - Fuel pressure gauge shows 35psi on startup. I didn't install this gauge but seems to work ok - Will fire with starting fluid I'm thinking I must be pretty close and suspect the car isn't getting fuel but the gauge shows pressure? |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
Cool, not sure what your issue was with the previous test. Button the injectors back up and verify you still have spark. Try starting the car
Groosh |
Cool, not sure what your issue was with the previous test. Button the injectors back up and verify you still have spark. Try starting the car I think we are missing something. The injectors do not fire when plugged into the ECU. They only fire when we jumped them. Could my ECU be bad? I tried pulling an injector and no fuel comes out when everything is put together. Additionally, I don't think I have spark anymore. The car did run on starter fluid in the being. But now it doesn't and looking for spark from a pulled plug reveals no spark. |
Lo-Fi Version | Time is now: 3rd April 2025 - 07:02 PM |
