Monday, 7 April 2025 |
Groosh |
Member ![]() ![]() Group: Members Posts: 50 Joined: 21-October 11 From: Dexter, MI Member No.: 13,702 Region Association: Upper MidWest ![]() |
Hi. I recently bought a '74 1.8 and am looking for help to get it running. It has the original fuel injection and ran late last year according the previous owner.
Here's what I know after reading many posts in the forum and working on it. Thanks to everybody who contributes, I couldn't have gotten this far without your help. - The dual relay is bad I believe. After wiring it all back up, there is power from the ignition to both the start wire and run wire but no power to the fuel pump. I'm jumping the pump currently to test - All relays in the board work - Fuel pressure gauge shows 35psi on startup. I didn't install this gauge but seems to work ok - Will fire with starting fluid I'm thinking I must be pretty close and suspect the car isn't getting fuel but the gauge shows pressure? |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
Just to make sure, did you pull all the wires off before testing? Positive to negative terminals should be around 4 ohms. Spark plug terminal to either terminal should be around 10,000 ohms.
Groosh |
Just to make sure, did you pull all the wires off before testing? Positive to negative terminals should be around 4 ohms. Spark plug terminal to either terminal should be around 10,000 ohms. Yes, the wires were pulled. However I retested. This time I used a digital meter and found 4 ohms and about 9,470 ohms from the spark plug terminal. |
Lo-Fi Version | Time is now: 7th April 2025 - 04:03 PM |
