stevegm |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,111 Joined: 14-July 14 From: North Carolina Member No.: 17,633 Region Association: South East States ![]() ![]() |
I need to remove the heads off of a newly rebuilt engine (4-cylinder) I built (never run). They have already been torqued. Are the head gaskets and gasket between the cylinder and block, compression gaskets that should be thrown away (i.e., replaced with new one) after I untorque the heads?
The head gaskets will be easy to replace. But I'd have to pull the cylinders to replace the ones between them and the block. |
Keyser Sose |
Member ![]() ![]() Group: Members Posts: 57 Joined: 1-July 14 From: West Member No.: 17,576 Region Association: None ![]() |
Cool, but I wouldn't depend on Haynes as gospel, and if you're going to defer to the engineer who designed the engine then you need to eliminate those gaskets. Here, the last word from VW on that subject:
http://www.ratwell.com/mirror/www.dolphins...m/techbull.html My own experience is that the failure rate is very small, maybe a percent or two and after a lot of miles, but those are still failures and there's no need for it. I know some builders still use gaskets, so it's not certain death or anything, and of course you can do anything you want with your own engines. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Cool, but I wouldn't depend on Haynes as gospel, and if you're going to defer to the engineer who designed the engine then you need to eliminate those gaskets. Here, the last word from VW on that subject: http://www.ratwell.com/mirror/www.dolphins...m/techbull.html My own experience is that the failure rate is very small, maybe a percent or two and after a lot of miles, but those are still failures and there's no need for it. I know some builders still use gaskets, so it's not certain death or anything, and of course you can do anything you want with your own engines. The tech bulletin specifically calls out "Models(s): Type II/Vanagon 1975 - 83 MY Date: May 31, 1990" I don't see Type IV anywhere in the listing, much less the 914. |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Cool, but I wouldn't depend on Haynes as gospel, and if you're going to defer to the engineer who designed the engine then you need to eliminate those gaskets. Here, the last word from VW on that subject: http://www.ratwell.com/mirror/www.dolphins...m/techbull.html My own experience is that the failure rate is very small, maybe a percent or two and after a lot of miles, but those are still failures and there's no need for it. I know some builders still use gaskets, so it's not certain death or anything, and of course you can do anything you want with your own engines. The tech bulletin specifically calls out "Models(s): Type II/Vanagon 1975 - 83 MY Date: May 31, 1990" I don't see Type IV anywhere in the listing, much less the 914. you DO realize that the engine is exactly the same (with respect to the head sealing interface) as the 914 don't you? |
Lo-Fi Version | Time is now: 25th June 2024 - 08:10 PM |
