malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
I want to cover all my bases here. I have purchased the new GB CHT sensor from 914Rubber to try.
So, I think I will buy a spacer from Brad Mayeur to have the option. From what he says it should: "Porsche 914/4 Cylinder Head Temperature Sensor Extension. This little device slows down the heating of the sensor and improves warm up drivability." I do have "warm up drivability" problems = Low idle RPM until the VDO CHT hits about 250*F. So it seems like my problems don't need the warm up to slow down, it needs to SPEED UP. (IMG:style_emoticons/default/WTF.gif) 914LTD.com ![]() ![]() Also found on RATWELL (scroll down to WORKAROUNDS)http://www.ratwell.com/technical/TempSensorII.html#parts |
pbanders |
Senior Member ![]() ![]() ![]() Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 ![]() |
See my edited response above.
BTW, it's nearly 100 deg. F here today, gotta love late October in Phoenix. I was out doing some errands, and I drove the 914, so I got several chances to try different hot start techniques. What worked best was to start with key off, then slightly crack open the throttle 1/4 of the way or less. Turn the key and crank, and hold the throttle steady until it starts, then back off slightly to keep the revs from going up too much. Now, hold the throttle at 2000 rpm for about 20 seconds to clear the plugs and get the heads warming up. Now, slowly close the throttle until you reach idle, it should be reasonably stable. If it ever cools off, I'll make the switchbox I describe in the posting above. With a more complex switching arrangement, you could make the box capable of lean or rich mixture. |
Lo-Fi Version | Time is now: 28th June 2024 - 11:12 PM |
