Engine Build Recommendadtion |
N_Jay |
Oct 29 2016, 11:03 AM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
OK, we have recently hashed out head gaskets, Pistons, rods, and bearings.
A while a go it was oil pumps. So what about a fresh build discussion. I plan on building a decent 2.0 based street engine. Goals are decent power, longevity and drivability. Think fun reliable touring with an occasional autocross. (Kind of what a factory 2.0 was good for, but with a little more kick in the pants.) AND reasonable price (Yes, that is always open to interpretation) What is recommended displacement? Bore and Stroke? What pistons, rods and cylinders? What compression? What cam? Guessing micro squirt or tuned up D-Jet. What "tricks" are worth while for a few HP and/or drivability, longevity, etc. What "tricks" are not worth while (or worst yet help one direction and hurt another) How much worse would it be to start with a 1.8 base? (Heads, etc.) |
tomh |
Oct 29 2016, 11:50 AM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
light flywheel is always an easy not too expensive add on for a little more kick.
stugray |
Oct 29 2016, 12:00 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
light flywheel is always an easy not too expensive add on for a little more kick. Be careful with those recommendations. Lightening the rotating mass does not necessarily give more horsepower. Reducing the rotating mass of the engine gives an almost negligible difference as compared to removing the mass from anywhere else on the vehicle. So removing mass from the rotating assembly is the lowest ROI as far as lbs/$$ goes. Now if you are building a race car from the ground up then, by all means, reduce weight wherever you can, including the engine. The best reason for reducing rotating mass is to minimize the forces on the crank and allow higher RPMs. For the greatest effect, the best place to reduce the mass is the conn-rods, wrist pins, & pistons. Reducing the mass of the flywheel (or crank) cannot give higher HP readings on an engine dyno (or the dyno operator is doing it wrong) (let the flames begin :-) |
tomh |
Oct 29 2016, 07:18 PM
light flywheel is always an easy not too expensive add on for a little more kick. Be careful with those recommendations. Lightening the rotating mass does not necessarily give more horsepower. Reducing the rotating mass of the engine gives an almost negligible difference as compared to removing the mass from anywhere else on the vehicle. So removing mass from the rotating assembly is the lowest ROI as far as lbs/$$ goes. Now if you are building a race car from the ground up then, by all means, reduce weight wherever you can, including the engine. The best reason for reducing rotating mass is to minimize the forces on the crank and allow higher RPMs. For the greatest effect, the best place to reduce the mass is the conn-rods, wrist pins, & pistons. Reducing the mass of the flywheel (or crank) cannot give higher HP readings on an engine dyno (or the dyno operator is doing it wrong) (let the flames begin :-) I guess I just got schooled LOL A few extra revs never hurt anyone, I sure like the little improvement it made on my 2.0 |
Lo-Fi Version | Time is now: 31st October 2024 - 07:28 PM |
