malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
I want to cover all my bases here. I have purchased the new GB CHT sensor from 914Rubber to try.
So, I think I will buy a spacer from Brad Mayeur to have the option. From what he says it should: "Porsche 914/4 Cylinder Head Temperature Sensor Extension. This little device slows down the heating of the sensor and improves warm up drivability." I do have "warm up drivability" problems = Low idle RPM until the VDO CHT hits about 250*F. So it seems like my problems don't need the warm up to slow down, it needs to SPEED UP. (IMG:style_emoticons/default/WTF.gif) 914LTD.com ![]() ![]() Also found on RATWELL (scroll down to WORKAROUNDS)http://www.ratwell.com/technical/TempSensorII.html#parts |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
Sorry, I know it wasn't helpful but I happen to love that schematic (IMG:style_emoticons/default/biggrin.gif)
I have a better idea. Consider a circuit that replaces your manual switch. This circuit most likely micro controller, would listen to the throttle position sensor. Before starting the car, you could depress the accelerator pedal 3 times, which would be recognized by the controller for lean behavior, 4 time for rich. The controller could be programmed to default back to normal conditions after a default time. |
Lo-Fi Version | Time is now: 26th June 2024 - 06:01 AM |
