malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
I want to cover all my bases here. I have purchased the new GB CHT sensor from 914Rubber to try.
So, I think I will buy a spacer from Brad Mayeur to have the option. From what he says it should: "Porsche 914/4 Cylinder Head Temperature Sensor Extension. This little device slows down the heating of the sensor and improves warm up drivability." I do have "warm up drivability" problems = Low idle RPM until the VDO CHT hits about 250*F. So it seems like my problems don't need the warm up to slow down, it needs to SPEED UP. (IMG:style_emoticons/default/WTF.gif) 914LTD.com ![]() ![]() Also found on RATWELL (scroll down to WORKAROUNDS)http://www.ratwell.com/technical/TempSensorII.html#parts |
nine9three |
Member ![]() ![]() Group: Members Posts: 142 Joined: 29-December 11 From: Oregon Member No.: 13,946 Region Association: Pacific Northwest ![]() |
I have the extension and it transformed my car when cold from a hunting idle to smooth as glass. No other issues when warm and still stable. All other components of the injection system function properly and are within spec. Because the ohm's change quickly with temperature there seems to be no issue with the described quick restart after warm rest. My experience has better than expected.
913B |
Senior Member ![]() ![]() ![]() Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None ![]() |
I have the extension and it transformed my car when cold from a hunting idle to smooth as glass. No other issues when warm and still stable. All other components of the injection system function properly and are within spec. Because the ohm's change quickly with temperature there seems to be no issue with the described quick restart after warm rest. My experience has better than expected. +1 I totally agree after installing a new CHT and extender, idle was still not so perfect until I cut that dang plastic connector where the CHT plugs into and but connected together, the idle is very steady with no fluctuations for a 40 yr old FI, couldn't be happier, ok maybe little more HP (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 28th June 2024 - 11:40 PM |
