malcolm2 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States ![]() ![]() |
I want to cover all my bases here. I have purchased the new GB CHT sensor from 914Rubber to try.
So, I think I will buy a spacer from Brad Mayeur to have the option. From what he says it should: "Porsche 914/4 Cylinder Head Temperature Sensor Extension. This little device slows down the heating of the sensor and improves warm up drivability." I do have "warm up drivability" problems = Low idle RPM until the VDO CHT hits about 250*F. So it seems like my problems don't need the warm up to slow down, it needs to SPEED UP. (IMG:style_emoticons/default/WTF.gif) 914LTD.com ![]() ![]() Also found on RATWELL (scroll down to WORKAROUNDS)http://www.ratwell.com/technical/TempSensorII.html#parts |
pbanders |
Senior Member ![]() ![]() ![]() Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 ![]() |
I have the tester box all put together, not wired yet. Didn't do Spoke's improvement because I couldn't get the center off switch added to my order, so it's not that elegant, but it still will work. Once I get it done, I'll start doing some testing, I should be able to have some experimental evidence to validate or refute a number of driveability issues we've attributed to rich and lean conditions.
Oh, and as always, I wish I'd used a slightly bigger project box, because it ended up being a tight fit, and I didn't have a lot of options on where to put some of the components, but it's ok as is. |
Lo-Fi Version | Time is now: 28th June 2024 - 11:02 PM |
