Adding a 915 trans to a 6 conversion, There must be a better way |
mepstein |
Nov 5 2016, 07:46 AM
914-6 GT in waiting Group: Members Posts: 19,597 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Is there any reason I shouldn't consider working up a cable shifter instead of the traditional 916 shift linkage. The current 916 kit is $3-3250. Add in labor for machining and assembly and you're at $5k just to make the trans shift correctly. The suby guys are doing the shifting with $300 worth of cables and hardware. Am I missing something here?
GeorgeRud |
Nov 5 2016, 08:07 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Even if you run a cable shifter setup, you still will need to flip the ring and pinion and machine for clearance, so there is some cost involved. My 915 has a Vellios kit that was carefully installed and massaged to shift well, but I was able to buy it for a little over a grand so it was a good deal.
With the exception of having to make provisions for a different muffler ( the banana muffler won't fit with the shifter taking that piece of real estate), I don't see where it couldn't be done. I seem to even remember seeing some photos of a 915 behind a V8 conversion, so give it a try! Please post photos and enjoy your project in good health! |
Lo-Fi Version | Time is now: 25th November 2024 - 02:48 PM |
