dlloyd2691 |
Newbie ![]() Group: Members Posts: 5 Joined: 29-April 16 From: Toronto Member No.: 19,951 Region Association: Canada ![]() |
Hello everyone. I'm a new owner of a 1975 914 1.8l (pictures shortly) with 75,000 miles. It was converted professionally to dual carbs from the original bosch fuel injection system. The car drives well but have noticed that when I park it in the garage after driving that a very strong gas smell lingers for days. I don't see any fuel leak. Is there a charcoal filter I've missed that needs replacing or can anyone recommend some items to check.
Pictures soon as I start the restore this winter, I'm a restore newbie so it should be painfully fun. Cheers, David |
bretth |
Senior Member ![]() ![]() ![]() Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region ![]() |
I am pretty sure the charcoal canister is located in the engine compartment on the battery tray. I have a 75 1.8 also but my canister is missing. FRom pics I have seen it should be in the engine compartment not the front trunk as earlier cars used to have.
Brett |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I am pretty sure the charcoal canister is located in the engine compartment on the battery tray. I have a 75 1.8 also but my canister is missing. FRom pics I have seen it should be in the engine compartment not the front trunk as earlier cars used to have. Up through early 1974 model year, the car had the charcoal canister mounted above the fuel tank. In mid-74, they moved the tank back into the engine bay. One of my 74s (the 1.8) had the engine-bay-mounted one, my 74 2.0 has the front-mounted one. Note that only the front-mounted canister cars have two plastic lines running through the rocker panel. The engine-bay canister cars have a single smaller line that runs through the center tunnel. --DD |
Lo-Fi Version | Time is now: 26th June 2024 - 02:42 AM |
