> DTM for a 914, Speak up if you want it developed!!
Jake Raby
post Oct 18 2004, 11:33 PM
Engine Surgeon
Okay guys... Give me some input here..
I am looking into making a completely new DTM system for a 914 application. It will utilize the stock oil cooler in the stock position and will fi with a modified rain tray (that would come with the kit).......... The basic shroud will stay the same and will keep in emphesis even running temps between the left and right bank cylinders and will do so about 25% better than the stock arrangement while looking alot neater and dropping 30-40 pounds of weigh off the engine and adding a ton of simplicity
It will come complete with all necessary tinware to seal the ebngine bay, and etc. It will only work with individual runners carbs/fi. I am working on an FI plenum for all my DTMS as we speak and that will be available in 2005.
So, who wants one or is even remotely interested? If I don't get 15 dedicated souls I'm not doing the development as its just not worth it to spend dozens of hours making the molds.
Cost would be around 700.00 for the complete kit.
SPEAK UP!!!!!!!
Jake Raby
post Oct 19 2004, 09:00 AM
Engine Surgeon
The system would have been a direct replacement for ANY type IV engine in a 914.
I have 200HP engines that run 50 degrees cooler than a stock 2.0 with all cylinders within 5% of each other with this system! This is on a drive from Baton Rouge to Orlando Florida at 85+ MPH..
One of my F production 914 guys runs the system and dropped 75 degrees off his head temps all the time and instead of doing valve adjustments after every race, now he does them every 4-5 races and finds them to be much more stable due to less expansion and contraction issues.
It amazes me how many people will let the looks of something over rule its fit, function and practicality. If someone saw one of my carbon fiber units in person they would never complin about looks ever again..
Jake Raby   DTM for a 914   Oct 18 2004, 11:33 PM
bernbomb914   I AM SPEAKING UP FOR THE 4TH TIME I WANT THE FIRST...   Oct 18 2004, 11:36 PM
Jake Raby   Get your friends to speak up too... I can't do...   Oct 18 2004, 11:38 PM
Elliot Cannon   I might like a new DTM system. What's a DTM s...   Oct 18 2004, 11:38 PM
Jake Raby   www.massivetype4.com Its a cooling system that I ...   Oct 18 2004, 11:39 PM
Elliot Cannon   We talking about the verticle fan shroud thing? K...   Oct 18 2004, 11:42 PM
bernbomb914   with this system you can kiss your overheating blu...   Oct 18 2004, 11:44 PM
Jake Raby   Nope, kinda sorta like a 356 or beetle. It uses a ...   Oct 18 2004, 11:47 PM
MattR   Jake, Im seriously thinking of investing in one. ...   Oct 19 2004, 12:01 AM
Jake Raby   available in February or so... (since I have a HUG...   Oct 19 2004, 12:04 AM
MattR   Does this kit replace all the shroud? Or would I ...   Oct 19 2004, 12:09 AM
Jake Raby   No stock tin is retained..... NONE< ZERO< ZILCH...   Oct 19 2004, 12:12 AM
MattR   Is it worth it with a 2056? And how do you keep t...   Oct 19 2004, 12:15 AM
bernbomb914   How much more for carbon fiber? Bernie   Oct 19 2004, 12:16 AM
Korijo   I am interested!   Oct 19 2004, 12:19 AM
Jake Raby   No matter how big the engine is it can benefit fro...   Oct 19 2004, 12:21 AM
MattR   The stock (700 dollar kit) is fiberglass, correct?...   Oct 19 2004, 12:29 AM
Jake Raby   The stock kit is fiberglass... The C/F shroud is 6...   Oct 19 2004, 12:30 AM
bernbomb914   will you be using the stock cooler or a new one th...   Oct 19 2004, 12:31 AM
Jake Raby   Two different versions will be available. One wil...   Oct 19 2004, 12:36 AM
bernbomb914   same price? Bernie   Oct 19 2004, 12:37 AM
Jake Raby   Nope, more $$$... Probably another ...   Oct 19 2004, 12:41 AM
bernbomb914   I want the first one with the new cooler location ...   Oct 19 2004, 12:46 AM
Jake Raby   I still need MORE interest... Probably a 100 buck...   Oct 19 2004, 12:53 AM
McMark   I like the idea of better cooling. I hate the ide...   Oct 19 2004, 12:53 AM
MattR   You'd take show over go Mark?   Oct 19 2004, 12:55 AM
McMark   Let me repeat... Unless a DTM is the only way I...   Oct 19 2004, 01:02 AM
Jake Raby   Some people don't need it... Put a gauge on a...   Oct 19 2004, 01:10 AM
bernbomb914   give us a paypal address bernie   Oct 19 2004, 01:26 AM
DNHunt   I'll consider it Jake. It'll have to be af...   Oct 19 2004, 07:20 AM
gopack   Jake, I would be interested, since I live in a pre...   Oct 19 2004, 07:37 AM
seanery   I'd be interested, but I'm in the same boa...   Oct 19 2004, 07:53 AM
Jake Raby   From what I have noted here there are a few guys t...   Oct 19 2004, 08:24 AM
JmuRiz   From looking at the DTM with the serpentine belt y...   Oct 19 2004, 08:52 AM
Jake Raby   The system would have been a direct replacement fo...   Oct 19 2004, 09:00 AM
JmuRiz   It amazes me as well, having seen the DTM on your ...   Oct 19 2004, 09:26 AM
Brett W   Jake Can I use the standard T4 shroud in my race c...   Oct 19 2004, 10:01 AM
Jake Raby   Brett, you should be able to with no issues. Mark...   Oct 19 2004, 10:12 AM
JmuRiz   ...I just got a little confused. Is the new 914 D...   Oct 19 2004, 01:45 PM
Jake Raby   It will come with a modified rain tray... It will...   Oct 19 2004, 01:52 PM
bob91403   Detractors :bootyshake: You go :worship: Jake. ...   Oct 19 2004, 05:03 PM
Cloudbuster   Eventually? Why not sign up for one now and save ...   Oct 19 2004, 05:11 PM
bob91403
- Lo-Fi Version Time is now: 31st October 2024 - 06:17 PM
