can you use 944 stub axel and hub in the rear of a 914, just a quick question |
tazz9924 |
Nov 16 2016, 09:37 AM
Senior Member Group: Members Posts: 716 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
i don't know the availability or cheepness of 911 parts for a 5 lug conversion but i do know 944 parts are fairly and cheep. Has anyone tried this?
914Sixer |
Nov 16 2016, 09:40 PM
914 Guru Group: Members Posts: 9,034 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
944 hubs will not work. Different splines. Basic 924/944 rear suspension was stolen from the VW Beetle UNTIL the Turbo 944 came along. You can use the Boxster hub BUT you will have to change out the 914 bearing plate to a flat one. Then you can use late 944 stub axle and CVS. The next problem is Boxter rotor is vented and you will need some sort of spacing to make a spaced 914 caliper work or use a 911 rear with some sort of adaptation.
Lo-Fi Version | Time is now: 27th December 2024 - 01:47 PM |
