> can you use 944 stub axel and hub in the rear of a 914, just a quick question
tazz9924
post Nov 16 2016, 09:37 AM
i don't know the availability or cheepness of 911 parts for a 5 lug conversion but i do know 944 parts are fairly and cheep. Has anyone tried this?
914Sixer
post Nov 16 2016, 09:40 PM
944 hubs will not work. Different splines. Basic 924/944 rear suspension was stolen from the VW Beetle UNTIL the Turbo 944 came along. You can use the Boxster hub BUT you will have to change out the 914 bearing plate to a flat one. Then you can use late 944 stub axle and CVS. The next problem is Boxter rotor is vented and you will need some sort of spacing to make a spaced 914 caliper work or use a 911 rear with some sort of adaptation.
tazz9924
post Nov 16 2016, 10:32 PM
QUOTE(914Sixer @ Nov 16 2016, 07:40 PM) *
when you say hub is the wrong splines what's wrong with using the 944 hub?
- Lo-Fi Version Time is now: 27th December 2024 - 01:39 PM
