Monday, 7 April 2025
> Oil system diagram, and oil cooler installation & routing
stugray
post Aug 15 2013, 02:24 PM
I would like to design a dry-sump type of system for my race car.
One thing I have found is that diagrams that show how the stock system works and how to modify it for other parts (coolers, dry sump, "full flow",etc) are hard to find.
So I made this diagram in Visio (CAD-like) so I can move parts around and ask the proper questions.
Does anyone have any suggestions or comments about making the diagram 100% correct before I start trying to modify it?
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1376598242.1.jpg)
I could provide the original file, but not too many out there have visio.
My next step is to get out a spare case so I can see EXACTLY where these parts go, exactly what any adapter might look like, and identify where all of the galley plugs would be in the diagram.
Stu
stugray
post Nov 17 2016, 11:28 PM
Ok, here;s my latest:
This is right after engine disassembly.
I put the oil system back on for a sec to get a picture.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1479446898.1.jpg)
What you see is a tangerine racing oil cooler blockoff plate.
In that I have 2X 3/8 NPT X 10AN adapters
The top port is the OUT from the engine's oil pressure relief valve (Also a Tangerine racing valve insert).
This line goes to a bracket on the side of the fan housing to 12AN lines that run to the front oil coolers.
The bottom port is the IN back towards the engine.
It has the return from the oil coolers from the left, through a one-way check valve then to the tee that feeds in to the engine.
Also connected to that tee is another 10AN that comes from my accusump.
Here's a side pic:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1479446898.2.jpg)
Here is a basic model of the standard OC block off plate:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1479446898.3.png)
If I made a modified blockoff plate, I could eliminate a lot of that plumbing.
So here is a plate that brings the AN fitting at a 90, eliminating one turn.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1479446899.4.png)
And on the back side, there would be a port for the accusump:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1479446899.5.png)
I think I will ask Cris if he can make one.
stugray   Oil system diagram   Aug 15 2013, 02:24 PM
yeahmag   I wouldn't try and reinvent the wheel... The C...   Aug 15 2013, 02:27 PM
stugray   the CB dual pump was going to be one of my first c...   Aug 15 2013, 03:21 PM
mrbubblehead   i posted some diagrams of my system but they were ...   Aug 15 2013, 03:40 PM
Jeff Bowlsby   Is this what you need?   Aug 15 2013, 03:42 PM
stugray   mrbubblehead, please post links to your diagrams. ...   Aug 15 2013, 05:27 PM
Racer Chris   I'm developing a kit to delete the stock coole...   Aug 16 2013, 06:40 AM
worn   I'm developing a kit to delete the stock cool...   Aug 17 2013, 10:42 PM
Racer Chris   Hi Chris, I want it. Do I have to drop the engin...   Aug 18 2013, 07:33 AM
motorvated   You labeled the oil filter bypass incorrectly.   Aug 16 2013, 06:45 AM
mrbubblehead   heres my basic plan. i will have to draw up the fu...   Aug 16 2013, 03:51 PM
stugray   mrbubblehead, thank you. your diagrams from the o...   Aug 16 2013, 04:26 PM
stugray   Better diagram: http://www.914world.com/bbs2/uplo...   Aug 17 2013, 01:18 AM
Dave_Darling   You're not going to remove the cooler from the...   Aug 17 2013, 11:01 PM
ClayPerrine   You're not going to remove the cooler from th...   Aug 17 2013, 11:14 PM
stugray   The next stage is remote oil filter bracket with r...   Aug 18 2013, 12:40 AM
N_Jay   The next stage is remote oil filter bracket with ...   Sep 24 2016, 08:11 AM
stugray   So I went ahead and used the car for one season (p...   Nov 23 2015, 09:40 PM
stugray   Finally updated my drawing to match my current con...   Sep 24 2016, 07:26 AM
Kansas 914   Great work and write up. I need to do something on...   Sep 24 2016, 07:44 AM
stugray   Ok, here;s my latest: This is right after engine ...   Nov 17 2016, 11:28 PM
Mark Henry   What was wrong with buying the $10 off the sh...   Nov 18 2016, 06:40 AM
stugray   What was wrong with buying the $10 off the s...   Nov 18 2016, 11:21 AM
Mark Henry   [quote name='Mark Henry' post='2424396' date='Nov...   Nov 18 2016, 01:19 PM
bulitt   Owned a car once with factory dry sump and the res...   Nov 18 2016, 07:30 AM
- Lo-Fi Version Time is now: 7th April 2025 - 04:40 AM
