slotty008 |
Member ![]() ![]() Group: Members Posts: 191 Joined: 11-November 15 From: Belgium Member No.: 19,349 Region Association: None ![]() ![]() |
I want to have the car repainted in the original colour without removing the engine or the interior. According to the body shop it's possible that the paint will peel off after some time because of the incompatibilty of the new and old paints. The car has been repainted before but the green the PO used is not the original Palma Green and there are some dents and scratches that need to be removed. Rust is not a problem.
So how do I remove the paint? (chemical paste, sander,...) |
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
If money was no object, you could use CO2 ice blasting.
It leaves nothing behind except the paint dust that was removed. The "old" Jasco paint remover worked like a miracle and would strip paint off the car to bare metal in seconds. The new stuff is not nearly as aggressive. Aircraft paint remover is the best that I have found recently. |
Lo-Fi Version | Time is now: 18th June 2024 - 07:39 AM |
