Gunn1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None ![]() |
Anyone have a drive by wire set up on their 914? Looking for a cable-less solution to throttle control. Would be for a stock 75' 914 2.0liter. (IMG:style_emoticons/default/driving.gif)
Gunn1 |
Your probably right, must likely the reason there is not a plug and play kit available. I'm not a liability attorney, but couldn't the same be said for some non factory modifications that potentially caused the accident.
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Your probably right, must likely the reason there is not a plug and play kit available. I'm not a liability attorney, but couldn't the same be said for some non factory modifications that potentially caused the accident. https://m.summitracing.com/parts/lok-xdbw-6...kxbEaAtAp8P8HAQ Plus you need another module that cost $300+ .... see tab for other parts So yes it can be done with properly engineered parts. |
Lo-Fi Version | Time is now: 18th June 2024 - 08:15 AM |
