Gunn1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None ![]() |
Anyone have a drive by wire set up on their 914? Looking for a cable-less solution to throttle control. Would be for a stock 75' 914 2.0liter. (IMG:style_emoticons/default/driving.gif)
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
This is one of those questions where if you have to ask you really shouldn't be doing it...
The difference between an arduino and PLC is the hardened electronics. The coding is trivial, but I would really not trust the reliability of an ardiuno in a life or death application. My car is going to DBW with an aftermarket engine controller, but using oem components like BarryM used for his car wouldn't be too hard. |
Gunn1 |
This is one of those questions where if you have to ask you really shouldn't be doing it... The difference between an arduino and PLC is the hardened electronics. The coding is trivial, but I would really not trust the reliability of an ardiuno in a life or death application. My car is going to DBW with an aftermarket engine controller, but using oem components like BarryM used for his car wouldn't be too hard. The question was "Anyone have a drive by wire set up on their 914? Looking for a cable-less solution to throttle control. Would be for a stock 75' 914 2.0liter." Never said I wanted to invent, or devise a system that would accomplish the DBW. I know a little bit about electronics and wiring, but nothing about writing code. I had thought there might already be a Kit (plug and Play) for purchase and installation. (IMG:style_emoticons/default/idea.gif) |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
This is one of those questions where if you have to ask you really shouldn't be doing it... The difference between an arduino and PLC is the hardened electronics. The coding is trivial, but I would really not trust the reliability of an ardiuno in a life or death application. My car is going to DBW with an aftermarket engine controller, but using oem components like BarryM used for his car wouldn't be too hard. The question was "Anyone have a drive by wire set up on their 914? Looking for a cable-less solution to throttle control. Would be for a stock 75' 914 2.0liter." Never said I wanted to invent, or devise a system that would accomplish the DBW. I know a little bit about electronics and wiring, but nothing about writing code. I had thought there might already be a Kit (plug and Play) for purchase and installation. (IMG:style_emoticons/default/idea.gif) There is not kit and will never be one because there is no market for it unless cables become obsolete or banned which is not going to happen. Someone would offer a dual carb setup before a stock throttle body setup since linkage on dual carbs can be more trouble to get right than a single carb. And before you ask, NO ,there is not a bolt on kit for ABS brakes for a stock 914 2.0, there is not a bolt on kit for traction control or a bolt on kit to make the car self driving. |
Lo-Fi Version | Time is now: 18th June 2024 - 08:12 AM |
