| Tom73 |
Oct 20 2004, 05:56 AM
Member ![]() ![]() Group: Members Posts: 180 Joined: 20-September 04 From: Central Texas Member No.: 2,792 |
Just got a '71 1.7 and two of the fuel injectors fuel hoses (the hose from the fuel rail/line to the injector) have cracked, apparently from age. I hate the thought of having to replace the injector just because the fuel hose part is cracked. Is there any way to replace that section of fuel line? It appears to be a press fit onto the injector. So, $150+ for new injector or $1.50 for new fuel line? Ideas????
tom... |
| Rhodes71/914 |
Oct 20 2004, 11:23 AM
Glacier ![]() ![]() ![]() Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Be sure that if you go with regular fuel hose to leave enough room for the rails to lay a little flatter than they were with the elbows. First time I did this the line from the pressure regulator to the fuel rail was too short, causing a kink in the little peice of line from the injector to the fuel rail. When I checked PP didn't have the elbows. Also if you're not already you might as well replace all the fuel lines. Cheap easy insurance.
By the way my car - '71 1.7L . (IMG:style_emoticons/default/biggrin.gif) |
Tom73 Fuel Injectors Oct 20 2004, 05:56 AM
Joe Ricard New fuel ine. If you want to get picky PP has the... Oct 20 2004, 06:26 AM
Tom73 How do you get the old hose line off since it is a... Oct 20 2004, 06:40 AM
type47 yes, there is a "barb" on the end of the injector ... Oct 20 2004, 07:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th September 2026 - 01:01 AM |
