mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,953 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
So I am building a 2.4 6 with s pistons, solex cams and ported heads. I have webers and have considered a couple of paths. I have used megasquirt in the past on a 3.2 short stroke turbo engine using an adaptation of the bitz racing kit..
I am considering many things from machining the intakes to accept injectors and using the webers as throttle bodies to making a all sheet metal intake.. I would really like use a ecu that has a usb port etc. I am looking for feed back .. Utlimatly the system I used before was bullet proof.. Thoughts? |
914forme |
Times a wastin', get wrenchin'! ![]() ![]() ![]() ![]() Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None ![]() ![]() |
Been considering the same thing.
I will go SDS as I have it, but MegaSquirt Pro would have been my next choice. The TBs are the big piece for me also. I have been thinking PMO as they would look stealth, but then the engine would not look stock anyway with a big coil pack hanging around. But as I have a set of triple speeds laying around, a set of manifolds, and it looks like I am well on my way. Now to rig up the ignition and fuel timing into the flywheel. |
ConeDodger |
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,628 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California ![]() ![]() |
Been considering the same thing. I will go SDS as I have it, but MegaSquirt Pro would have been my next choice. The TBs are the big piece for me also. I have been thinking PMO as they would look stealth, but then the engine would not look stock anyway with a big coil pack hanging around. But as I have a set of triple speeds laying around, a set of manifolds, and it looks like I am well on my way. Now to rig up the ignition and fuel timing into the flywheel. Steven, having used SDS for a couple years, my concern is with the first S in SDS. Compared to either Mega or Micro, it's just too simple. It's lack of sophistication, especially in the tuning interface left me struggling to get things just right. When you do something like this, you are wanting it just right. Otherwise bolt up carbs and go! The prices between the systems are comparable. So, why? McMark was very patient with me but I think he would have rather done any other system. |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Been considering the same thing. I will go SDS as I have it, but MegaSquirt Pro would have been my next choice. The TBs are the big piece for me also. I have been thinking PMO as they would look stealth, but then the engine would not look stock anyway with a big coil pack hanging around. But as I have a set of triple speeds laying around, a set of manifolds, and it looks like I am well on my way. Now to rig up the ignition and fuel timing into the flywheel. Steven, having used SDS for a couple years, my concern is with the first S in SDS. Compared to either Mega or Micro, it's just too simple. It's lack of sophistication, especially in the tuning interface left me struggling to get things just right. When you do something like this, you are wanting it just right. Otherwise bolt up carbs and go! The prices between the systems are comparable. So, why? McMark was very patient with me but I think he would have rather done any other system. He says because he already has the system.... BTW on your SDS, let me guess, it always went lean if you kicked down WOT... (IMG:style_emoticons/default/idea.gif) |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Been considering the same thing. I will go SDS as I have it, but MegaSquirt Pro would have been my next choice. The TBs are the big piece for me also. I have been thinking PMO as they would look stealth, but then the engine would not look stock anyway with a big coil pack hanging around. But as I have a set of triple speeds laying around, a set of manifolds, and it looks like I am well on my way. Now to rig up the ignition and fuel timing into the flywheel. Steven, having used SDS for a couple years, my concern is with the first S in SDS. Compared to either Mega or Micro, it's just too simple. It's lack of sophistication, especially in the tuning interface left me struggling to get things just right. When you do something like this, you are wanting it just right. Otherwise bolt up carbs and go! The prices between the systems are comparable. So, why? McMark was very patient with me but I think he would have rather done any other system. He says because he already has the system.... BTW on your SDS, let me guess, it always went lean if you kicked down WOT... (IMG:style_emoticons/default/idea.gif) It was mostly just the feverish masturbation of buttons trying to navigate to the correct 'bin' that needed adjustment. Oh and the 4-up view of engine readings instead of the Tuner Studio dash were everything is in one place. (IMG:style_emoticons/default/wink.gif) My standard caveat applies: SDS works, some people love it, I know it works. It just doesn't fit my needs. |
Mark Henry |
My standard caveat applies: SDS works, some people love it, I know it works. It just doesn't fit my needs. Yep, I hear you...not for everyone. Even my next system will likely be MS. As for SDS, you do know the new systems have changed a bit. It still has a pendant, but it's now fully programmable via laptop with datalogging, etc. If anyone wants an SDS /6, crankfire twin plug system, I have a line on one for a good price. Includes everything, trigger wheel, sensor mount, two coil packs (twin plug) I believe the plug wire sets, a 1 bar and 2 bar MPS. Used one season, no issues, bought new in 2014. Was on a 930 turbo making 450hp at the wheels, no idea why the dude wants to change, runs perfect to me and he's not going to gain anything. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:31 AM |
