> Squeaky roof?, new car has a squeaky roof
Will Hesch
post Dec 18 2016, 03:09 PM
We purchased a 75 2.0 yesterday but the roof squeaks going over bumps.
Is this normal?
Is there a cure?
All new rubber front/windshield and top of "roll-bar".
Thanks, Will
Mikey914
post Dec 18 2016, 03:12 PM
The rubber man
Usually no fuzzey on the rear targa seal is the source.
Will Hesch
post Dec 18 2016, 03:36 PM
QUOTE(Mikey914 @ Dec 18 2016, 01:12 PM) *
Thanks Mikey, I was going to put a strip of terry-cloth on it to see if that quieted it, your reply confirmed what I suspected and no, there's no "fuzzy" on the top.
Will
Will Hesch   Squeaky roof?   Dec 18 2016, 03:09 PM
Mikey914   Usually no fuzzey on the rear targa seal is the so...   Dec 18 2016, 03:12 PM
Will Hesch   Usually no fuzzey on the rear targa seal is the s...   Dec 18 2016, 03:36 PM
The Cabinetmaker   Another squeak spot is the rubber blocks on the Ta...   Dec 18 2016, 03:40 PM
wndsrfr   Another squeak spot is the rubber blocks on the T...   Dec 19 2016, 07:36 AM
Will Hesch   Another squeak spot is the rubber blocks on the ...   Dec 19 2016, 12:34 PM
914_teener   [quote name='wndsrfr' post='2435373' date='Dec 19...   Dec 19 2016, 12:51 PM
Will Hesch   [quote name='wndsrfr' post='2435373' date='Dec 1...   Dec 19 2016, 02:30 PM
vw_porsche   I put a small peice of vacuum hose over the ...   Jun 13 2017, 09:50 AM
jor   I put a small peice of vacuum hose over the ...   Jun 13 2017, 12:42 PM
wndsrfr   [quote name='wndsrfr' post='2435373' date='Dec 19...   Dec 19 2016, 01:30 PM
maf914   You can spray the old roof seals with silicon for ...   Dec 18 2016, 05:15 PM
rhodyguy   The 2 rubber standoffs are a common culprit. I put...   Dec 19 2016, 09:15 AM
Will Hesch   Rhodyguy, that's a good idea, thanks! Will   Dec 19 2016, 12:35 PM
rhodyguy   The little bit of thickness helps to tighten up th...   Dec 19 2016, 12:41 PM
Will Hesch   Thanks to all of you guys for the suggestions and ...   Dec 19 2016, 02:31 PM
jor   My top is squeaking like a tortured mouse. Like a...   Jun 13 2017, 09:27 AM
sb914   I Hardley Ever drive with top on. Part of the beau...   Jun 13 2017, 09:51 AM
SirAndy   The squeak comes from the trapezoid shaped hard ru...   Jun 13 2017, 01:39 PM
jor   The squeak comes from the trapezoid shaped hard r...   Jun 14 2017, 09:13 AM
MikeM   Can you post a photo please? Thanks   Jun 14 2017, 09:17 AM
- Lo-Fi Version Time is now: 15th January 2025 - 09:55 AM
