Harpo |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None ![]() |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Here is the one I made in 2002 for my car. It is still in there and working fine.
![]() ![]() ![]() I cut the mount off a 4 cylinder column, and welded it to a 911 column. I had to trim the front edges of the clamshell to get them to fit, and I have to remove the clamshells to get the tach out of the dash. I also trimmed the 911 key bezel down to fit in the 914. |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
[I also trimmed the 911 key bezel down to fit in the 914. How did you trim the bezel ? I need to do that..... (IMG:style_emoticons/default/smile.gif) |
ClayPerrine |
[I also trimmed the 911 key bezel down to fit in the 914. How did you trim the bezel ? I need to do that..... (IMG:style_emoticons/default/smile.gif) 1. Made a fixture for my drill press to hold the bezel. A couple of washers that would fit inside and an 8MM bolt. 2. Used tin snips to cut down the bezel close to where I wanted it. 3. Mounted the cut down bezel in the drilll press. 4. Spun it round and round while using progressively finer files. 5. Finished it off with a progression of finer and finer sandpaper. That's about it. Simple, no need to get fancy. |
Lo-Fi Version | Time is now: 25th June 2024 - 06:53 PM |
