Targa Main Seal, OEM vs. Original Porsche |
74914LE |
Dec 29 2016, 12:46 PM
Member Group: Members Posts: 136 Joined: 6-April 04 From: Fort Worth, TX Member No.: 1,895 |
Has anyone seen one of the "OEM" Targa Main Seals that are available, to be able to tell me if it is 100% the same as an Original Porsche Seal? Just curious, since Original Seals are available from Porsche, is "OEM" 100% from the same mold/material? It looks like about a $100 price difference, and not sure the Porsche bag is worth that much it they are 100% the same.
Part No.- 91456303910 Thanks in advance for opinions! (IMG:style_emoticons/default/smile.gif) |
Mikey914 |
Dec 30 2016, 10:26 AM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Do the sides 1st. Then start in the middle and press on the top. The grip is tight, so if you have to use a flat screwdriver to open up about 1" to get started. You can also use soapy water to help it slide on. You really don't want to have to take off and reinstall. So don't stretch it (making one side have more material).
Patience as it is tight so it will not pull off. MArk |
Lo-Fi Version | Time is now: 25th September 2024 - 10:38 PM |
