Where is the HorsePower breakpoint?, For adding flares |
boxsterfan |
Dec 30 2016, 09:13 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
As I sit here pondering my 914 restore, I was wondering what others thought the breakpoint was for adding flares to a 914 vs staying narrow body?
Seems like at a certain horsepower, you are going to need some more rubber for the road. What's the general thought? Is it around 175HP (~2.7L /6 ?), 190HP (~3.0L /6 ?), 220HP (3.2L /6 ?) or more? I recognize that there are also some considerations with tire choices also. Even on the narrow body car, you may have to roll the fender just a bit to get a bigger tire on there just for the sake of selection/choice of manufacturer tires. |
Steve |
Dec 30 2016, 10:47 PM
914 Guru Group: Members Posts: 5,622 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
If you drive nice it's not a problem. My issue was throttle induced oversteer. Just upgrading to a 2.7 six with webers, caused very dangerous throttle induced oversteer with my car. I only had this problem when giving it to much gas in a corner
Curious if a limited slip differential would of helped?? Instead I cut off the rear fenders and installed 993 16" rims with 245 series tires, that and a stiffer roll bar up front, helped a lot. I bought a set of fiberglass Gt rear flairs and riveted them on. Now even with modest throttle in a corner, the car will just slide sideways versus spinning out. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:44 PM |
