Rear caliper issue, Inner piston won't retract |
brownaar |
Jan 5 2017, 09:46 AM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
I've been having issues with parking brake not releasing on the driver's side. Pulled caliper today. Arm would not release. Removed spring, blasted and cleaned around the parking brake arm, moves much more freely now. The problem I have is I don't think the inner piston is retracting appropriately, if at all. See picture below. That doesn't look fully retracted to me. The inner adjuster will push the piston further out of the bore, but I can not get it to retract the piston back into the bore. Can I use a clamp to retract the piston or is that a BAD IDEA? Has the piston come off the end of the adjuster, or is that possible? Scratching my head here.
Thanks, Aaron |
Lo-Fi Version | Time is now: 25th June 2024 - 12:19 AM |
