Ansbacher |
Senior Member ![]() ![]() ![]() Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 ![]() |
Other day at the FLAPS I purchased what I thought was 85/90 gear oil for my '74 2.0L. After filling the gear case I realized I had picked a bottle of 85/W145. The car has never driven better and is much quieter than it used to be. Seems like my mistake was for the good, but are there any hazards/drawbacks to using this heavier weight oil? So far it has been an improvement.
Ansbacher |
maf914 |
Not a Guru! ![]() ![]() ![]() ![]() Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None ![]() ![]() |
Interesting question.
The Haynes manual indicates the tranny capacity to be 2.6 quarts of 90W hypoid gear oil. Did you put in all 85/W145 oil? Or did you mix the 85/W145 with 85/W90, and if so, what quantity of each? I hope someone can comment on what the resulting weight is when oils of different weights are mixed. (IMG:style_emoticons/default/idea.gif) |
6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
Interesting question. The Haynes manual indicates the tranny capacity to be 2.6 quarts of 90W hypoid gear oil. Did you put in all 85/W145 oil? Or did you mix the 85/W145 with 85/W90, and if so, what quantity of each? I hope someone can comment on what the resulting weight is when oils of different weights are mixed. (IMG:style_emoticons/default/idea.gif) the W has nothing to do with the weight of the oil its code for winter and the lower the W # the easier it flows and how viscous it is at that temp..research Conoco/phillips oil numbers so the OP put in 85W/145..not 85/W145 .... its been ingrained in most motor heads over the years to the point we just call it 90 weight gear lube when its really not at all Just so ya know (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 24th June 2024 - 11:54 PM |
