Cylinder/case seal. |
Keith914 |
Jan 4 2017, 11:26 AM
Member Group: Members Posts: 248 Joined: 29-April 16 From: Laguna Beach, California 92651 Member No.: 19,948 Region Association: Southern California |
My recently rebuilt Type IV is leaking oil between the cylinders and the case. This engine is now a 2.4 L (was 1.7) with no gaskets or shims between the cylinders and the case -- common practice. So what is the best sealant and best method of application?
forrestkhaag |
Jan 5 2017, 03:14 PM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Yamabond 4 is my engine-builder pal's choice and notes that in his race experience, it holds up in cylinder to case applications that see 10K rpms regularly. This goo is a silicone based liquid gasket that fills gaps on a flange surface and prevents leaks. When cured, this product forms a rubber-like body that resists heat and seals joints subjected to high temperature. It is gear and engine oil resistant, Yamabond 4 Motorsports sets in 60 minutes so you have time to work with it if chasing rings etc.
(IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
Mark Henry |
Jan 6 2017, 01:20 PM
Lo-Fi Version | Time is now: 24th September 2024 - 01:03 PM |
