tazz9924 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None ![]() |
When you have a re drilled rear hub (5 lug) is there certain rotors you cant use and can you use 911 ebrake with the 914 hub?
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,733 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
You need 911 rotors. There is extra material inside the rotor where the e brake pads make contact. I'm not sure if you have to match your assembly with the correct year 911 rotor or if the iD of that area is the same for all years.
Lo-Fi Version | Time is now: 24th June 2024 - 11:27 PM |
