re drilled rear hub question |
tazz9924 |
Jan 7 2017, 12:32 PM
Senior Member Group: Members Posts: 716 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
When you have a re drilled rear hub (5 lug) is there certain rotors you cant use and can you use 911 ebrake with the 914 hub?
Dave_Darling |
Jan 7 2017, 04:48 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
That's two separate questions.
First, if you have re-drilled rear hubs you can use the 914-6 rear rotors. You may have to shim the caliper outward a touch or take a bit of material off the outer edge, as some report a bit of interference with the caliper. Second, if you want to use the 911 brake mechanism you have to use the 911 rear rotors, and do some fabrication to mount the mechanical calipers and the cables and so on. --DD |
Lo-Fi Version | Time is now: 26th September 2024 - 11:40 AM |
