oakdalecurtis |
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,329 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California ![]() ![]() |
I'm installing some replacement trigger points in my dizzy shortly. I read somewhere to use a small amount of lube on the cam lobes where they contact the trigger points before reassembly. Can anyone tell me specifically what brand or type of lube to use that I might be able to get at my local FLAPS?
Thanks |
PlaysWithCars |
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest ![]() ![]() |
I use Bosch 5700002005 distributor grease. It is available online through Amazon and other sources, but it may not be available at your local FLAPS. I'm sure there are other lubricants that would work fine, but you did ask for specifics...and the Bosch grease is specifically what is called for. (IMG:style_emoticons/default/smile.gif) What he said ........... (IMG:style_emoticons/default/agree.gif) It's pretty unique grease. Very sticky. I'm presuming to stay in place and not sling all around the distributor. |
oakdalecurtis |
I use Bosch 5700002005 distributor grease. It is available online through Amazon and other sources, but it may not be available at your local FLAPS. I'm sure there are other lubricants that would work fine, but you did ask for specifics...and the Bosch grease is specifically what is called for. (IMG:style_emoticons/default/smile.gif) What he said ........... (IMG:style_emoticons/default/agree.gif) It's pretty unique grease. Very sticky. I'm presuming to stay in place and not sling all around the distributor. ty guys, exactly what I wanted to know! |
Lo-Fi Version | Time is now: 28th June 2024 - 01:59 PM |
