oakdalecurtis |
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,329 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California ![]() ![]() |
I'm installing some replacement trigger points in my dizzy shortly. I read somewhere to use a small amount of lube on the cam lobes where they contact the trigger points before reassembly. Can anyone tell me specifically what brand or type of lube to use that I might be able to get at my local FLAPS?
Thanks |
mark04usa |
'70 1.7 Tangerine ![]() ![]() Group: Members Posts: 351 Joined: 14-September 09 From: Austin TX Member No.: 10,805 Region Association: Southwest Region ![]() ![]() |
I use Bosch 5700002005 distributor grease. It is available online through Amazon and other sources, but it may not be available at your local FLAPS. I'm sure there are other lubricants that would work fine, but you did ask for specifics...and the Bosch grease is specifically what is called for. (IMG:style_emoticons/default/smile.gif)
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,603 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
I use Bosch 5700002005 distributor grease. It is available online through Amazon and other sources, but it may not be available at your local FLAPS. I'm sure there are other lubricants that would work fine, but you did ask for specifics...and the Bosch grease is specifically what is called for. (IMG:style_emoticons/default/smile.gif) ![]() Looked at a few places but doesn't seem to be available anymore (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 28th June 2024 - 01:46 PM |
