billh1963 |
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States ![]() |
Been thinking about my needs and realize that I not only need a conditioned work and storage place but I also need long term dry storage.
One big building would be nice. However, a large portion of it would be storage. That would be expensive to heat and cool. For the same money (actually a little less) I'm going with two 1200 sq. ft. garages linked by a 30' pad (the one in the drawing is 20' to save space on the drawing). This pad would give me a place to wash cars and work outside on nice days. The buildings will have 10' roll up doors on each end, one walk out door and two windows (around 6'-7' up for security) which are not shown in my rough drawing. The drawing is to scale with the cars being current 911 sized I put the deposit down today and have a few days to make any last minute adjustments. I had lots of good suggestions last time that I will be incorporating such as a loft (not shown on the drawings) . Based on previous feedback I need to spend more time thinking the layout of the bathroom (if I have one) and sink areas. The tool and storage rooms drawn are just for me to think about. Interior layout is something I will add later after the building are up. So, is there a fatal flaw or anything I am overlooking in this design? As I mentioned, I have a few days to make changes before the design/build process kicks off. Slab will be poured in around 4 weeks and building go up in 6 to 8 weeks. ![]() |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,041 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
First off, you can't have too many garage doors.
That said, in my opinion, the only way your design works is if you add enough width to the buildings so that you can park cars perpendicular to the side walls. That way, your central aisle becomes functional as a thru passage and individual cars can be moved at will instead of the jockeying now required. You could even install a four post lift(s) to increase storage capacity, depending on your roof height. BTW, where is your lift going to live? The arrangement I've described also makes it more convenient for displaying your cars as the storage area becomes a man cave. There are few things more fun than planning and executing a work and storage area for your cars. Good luck...enjoy! (IMG:style_emoticons/default/aktion035.gif) |
billh1963 |
First off, you can't have too many garage doors. That said, in my opinion, the only way your design works is if you add enough width to the buildings so that you can park cars perpendicular to the side walls. That way, your central aisle becomes functional as a thru passage and individual cars can be moved at will instead of the jockeying now required. You could even install a four post lift(s) to increase storage capacity, depending on your roof height. BTW, where is your lift going to live? I've thought about two doors on the left building. That may allow better access. The cars are drawn about 20-25% bigger than they will be in real life to show a "worst case" scenario. The two post lift will be in the center aisle on the end towards the connecting concrete pad. 4 post lifts are in the future plans. It may also make sense to move the doors to the outer walls |
Lo-Fi Version | Time is now: 28th June 2024 - 12:05 AM |
