billh1963 |
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States ![]() |
Been thinking about my needs and realize that I not only need a conditioned work and storage place but I also need long term dry storage.
One big building would be nice. However, a large portion of it would be storage. That would be expensive to heat and cool. For the same money (actually a little less) I'm going with two 1200 sq. ft. garages linked by a 30' pad (the one in the drawing is 20' to save space on the drawing). This pad would give me a place to wash cars and work outside on nice days. The buildings will have 10' roll up doors on each end, one walk out door and two windows (around 6'-7' up for security) which are not shown in my rough drawing. The drawing is to scale with the cars being current 911 sized I put the deposit down today and have a few days to make any last minute adjustments. I had lots of good suggestions last time that I will be incorporating such as a loft (not shown on the drawings) . Based on previous feedback I need to spend more time thinking the layout of the bathroom (if I have one) and sink areas. The tool and storage rooms drawn are just for me to think about. Interior layout is something I will add later after the building are up. So, is there a fatal flaw or anything I am overlooking in this design? As I mentioned, I have a few days to make changes before the design/build process kicks off. Slab will be poured in around 4 weeks and building go up in 6 to 8 weeks. ![]() |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,041 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
First off, you can't have too many garage doors.
That said, in my opinion, the only way your design works is if you add enough width to the buildings so that you can park cars perpendicular to the side walls. That way, your central aisle becomes functional as a thru passage and individual cars can be moved at will instead of the jockeying now required. You could even install a four post lift(s) to increase storage capacity, depending on your roof height. BTW, where is your lift going to live? The arrangement I've described also makes it more convenient for displaying your cars as the storage area becomes a man cave. There are few things more fun than planning and executing a work and storage area for your cars. Good luck...enjoy! (IMG:style_emoticons/default/aktion035.gif) |
billh1963 |
First off, you can't have too many garage doors. That said, in my opinion, the only way your design works is if you add enough width to the buildings so that you can park cars perpendicular to the side walls. That way, your central aisle becomes functional as a thru passage and individual cars can be moved at will instead of the jockeying now required. You could even install a four post lift(s) to increase storage capacity, depending on your roof height. BTW, where is your lift going to live? I've thought about two doors on the left building. That may allow better access. The cars are drawn about 20-25% bigger than they will be in real life to show a "worst case" scenario. The two post lift will be in the center aisle on the end towards the connecting concrete pad. 4 post lifts are in the future plans. It may also make sense to move the doors to the outer walls |
KELTY360 |
First off, you can't have too many garage doors. That said, in my opinion, the only way your design works is if you add enough width to the buildings so that you can park cars perpendicular to the side walls. That way, your central aisle becomes functional as a thru passage and individual cars can be moved at will instead of the jockeying now required. You could even install a four post lift(s) to increase storage capacity, depending on your roof height. BTW, where is your lift going to live? I've thought about two doors on the left building. That may allow better access. The cars are drawn about 20-25% bigger than they will be in real life to show a "worst case" scenario. The two post lift will be in the center aisle on the end towards the connecting concrete pad. 4 post lifts are in the future plans. It may also make sense to move the doors to the outer walls I'm going to be a 'buttinski' here so I won't be offended if you tell me to butt out. How many cars do you expect to be working on at any given time? Work-around space in the shop area is very important and you don't want to squeeze yourself as you move around the area. Floor space for things like engine, trannies, sheet metal must also be allowed for. Your current design makes moving things around like one of those slide puzzles where you have to shift tiles in order to get a certain tile from one side of the puzzle to the other. Open space is your friend. If the two post lift is in the middle of the aisle near the door you'll create a logjam if there's a project on the lift and you want to move something else around to the other building. Trust me, it happens. I've done a quick example showing a 35x40 (1400 sq ft) that could hold 6 cars with 10' rollups at both ends and easier circulation. I'm sure you can find space for benches and storage in this configuration. Note that the aisle is not straight-thru, but it's still wide enough to navigate safely with sufficient space allowed at the entrance and exit. Obviously, roof height and configuration are affected with the offset aisle, but those details can be worked out under the 'buttinski license". Good luck. ![]() |
Lo-Fi Version | Time is now: 28th June 2024 - 12:21 AM |
